After selling my VC4SL, I finally got the Vapcell S4+ (V3). It appears to be working (I’m only using it with NiMH), but I noticed that the temperature reading for channel 4 is always about 10 degrees higher than it should be, even when I first start it up cold. The other channels will be say 22 degrees, but channel 4 will read 32 degrees.
Anyone else see this?
I’m slightly disappointed. After finding the VC4SL to be totally incapable with NiMH, it took me a year to finally be convinced by the good reviews to get the S4+, but now I’m finding this issue.
That´s a minor issue for me. But I don´t look often at the temps because I use 500mA for AAA and 1A for AA, this should very rare lead to high temps. And also my other Chargers with temperature monitoring are mostly completely wrong if I compare with an Infrarot-thermometer.
@vapcell_Dennis Is this a known issue with the V3? If the temperature sensor is faulty, is there a chance that the charger will refuse to charge a cell because it thinks the temperature is too high?
Thanks for all the replies. Looks like my channel 4 temp sensor is faulty… The manual says that at temps of 65 degrees, it starts automatically lowering/limiting the charge current. I hope the faulty sensor doesn’t start giving readouts that high.
Thanks for your reply, @vapcell_Dennis.
The temperature sensor is +10 degrees immediately upon putting a cell in channel 4. My concern is that if there’s a problem with it now (some soldering issue or something loose), then the issue could start to get worse, eventually making channel 4 unusable.
I purchased the charger brand new and expect it to start at 100% functionality. Given that I’m dissatisfied with it and it is brand new, what is the process to have it replaced with a fully functional unit?
My V3 shows about 10 degrees higher on channel 4 than any of the other channels. I feel like channels 1-3 are about right, showing 23degrees (room temperature) at startup. All of the channels’ temperature readings move around during use, so none of them are “stuck”, but channel 4 is pretty much always 10 degrees higher than any of the other channels.
Sounds faulty to me. Unfortunately I bought from a company in China and I’m in Canada, so doing a return would cost me almost the price of the product to ship back.
