So I ordered several VBatty IMR14500 batteries from the VBatty AliExpress store.
based from HKJ's reviews, these 14500's should have around 800mAh with 0.5A current discharge test.
refer: https://budgetlightforum.com/t/-/44279
(800mAh tested capacity for an 880mAh labeled battery is 10% below, I would still call it "OK")
I did capacity testing for these batteries but I got only between 630-682mAh (see images)
But 700mAh tested capacity is more than 20% below. Do you think it's worth to call a dispute to the AliExpress store?
on SkyRC MC3000, charged to 4.20v, then discharge at 0.25A to 2.50v cut-off -- got 659, 682, 648, 664mAh)
on Opus BT-C3100 v2.2, Charge Test @ 200mA: I got 637, 630, 654, 656mAh
On Lii-500, NOR Test (Discharge test) @ 300mA current: 653, 668, 682, 672mAh
Average would be around 660mAh capacity at low drain rate (0.20A-0.30A discharge).
Would you consider this still within "tolerable" range for an 880mAh nominal capacity 14500?
Even if I compare against HKJ's results of "800mAh" capacity, 682mAh is 15% lower capacity..
