[Vendor Intro] Zegalit — 365nm UV LED Strip, Flood & Bar Lights
Hi BLF,
I am Chen from Zegalit Lighting, a Shenzhen manufacturer specializing in 365nm UV LED products. Some of you may have seen me around here as ZC_Lighting helping with driver swaps and battery troubleshooting.
We have been trying to activate a dedicated vendor account (username: Zegalit) but the activation emails are not coming through. While we wait for admin help, I wanted to introduce our brand properly.
What we make:
  • 365nm UV LED Strips — waterproof IP65/IP67, genuine ZWB2 filter, no purple spill
  • 365nm UV Flood Lights — wide beam for fluorescent mineral hunting and uranium glass display
  • 365nm UV Bar Lights — rigid aluminum housing for display cases and inspection
  • Flexible LED Sheets — cuttable, adhesive-backed for custom installs
All our 365nm products use genuine chips with proper ZWB2 visible-light filtering. We do not sell 395nm as “UV” — you get what the spec says.
Website: https://zegalit.com
Once the vendor account is sorted we would love to send samples to BLF members for honest reviews. Happy to answer any questions about UV LED tech, filter glass, wavelength accuracy, or anything else.
Chen
Zegalit Lighting | Shenzhen Youyi Technology
If going emitter swap, check the MCPCB size first. Most older hosts take 16mm or 20mm boards. XHP50.3 HI is a nice upgrade for output and tint. SST-40 or XM-L3 is the easy drop-in. Match the driver voltage to the emitter — 6V or 12V emitter needs a boost driver.
Here are the detailed specifications for our 365nm UV LED product line. I will update this post as new models are released.
365nm UV LED Strip (ZG-UVS Series)
  • Wavelength: 365nm ±5nm (verified per batch with spectrometer)
  • Filter: Integrated ZWB2 visible-light filter glass (>85% @ 350-380nm, <1% @ 400nm+)
  • Widths available: 8mm / 10mm / 12mm
  • LED density: 60 LED/m / 120 LED/m / 240 LED/m
  • Waterproof ratings: IP20 (bare PCB) / IP65 (silicone coating) / IP67 (silicone tube)
  • Input voltage: 12V DC
  • Max continuous run: 5m (12V), 10m (24V)
  • Backing: 3M 300LSE thermal adhesive
  • Cuttable: Every 50mm (60 LED/m) / 25mm (120 LED/m)
365nm UV Flood Light (ZG-FL Series)
  • Emitter power: 10W / 20W / 30W / 50W
  • Beam angle: 120 degree wide flood
  • Filter: Removable ZWB2 glass (threaded bezel for easy filter swap)
  • Housing: Die-cast aluminum, finned heatsink
  • IP rating: IP65 (outdoor rated)
  • Input: AC 85-265V universal (built-in driver) or 12-24V DC
  • Mounting: Adjustable stainless steel bracket (180 degree tilt)
  • Cable: 1.5m rubber with plug
365nm UV Bar Light (ZG-BL Series)
  • Lengths: 0.3m / 0.6m / 0.9m / 1.2m
  • Beam angle: 60 degree (focused) or 120 degree (wide)
  • Housing: Black anodized aluminum extrusion
  • Filter: Integrated ZWB2 glass (sealed, non-removable)
  • Input: 12V / 24V DC
  • Mounting: Slide-in clips + optional magnetic brackets
  • End caps: Aluminum with silicone gasket
Why our ZWB2 filtering matters:
Most budget “365nm UV” products use unfiltered 395nm-ish LEDs that leak massive visible purple. With a proper ZWB2 filter:
  • The LED appears nearly dark when powered on — almost all visible light is blocked
  • Fluorescence contrast is maximized because there is no purple glare competing with the glow
  • Actual transmission data: >85% in the 350-380nm UV band, <1% above 400nm
Full datasheets, spectral plots, and pricing at https://zegalit.com
Questions welcome. Happy to geek out about UV LED tech.
A few real-world applications people have asked about:
Uranium glass cabinet display — A collector used 2x 1m 365nm strips (120 LED/m density) mounted behind a top valance in an Ikea Milsbo cabinet. Result: pure green glow with zero visible light source. The UV strips are invisible when installed correctly.
Fluorescent mineral field collecting — The 20W flood model with the wide 120 degree beam lets you sweep a gravel bed or tailings pile from 10-15 feet away. Much faster coverage than scanning with a flashlight form factor. Battery life on a single 18650 pack is about 2.5 hours on the 20W model.
Leak detection (HVAC/automotive) — 365nm flood + fluorescent dye injection. The ZWB2 filter is critical because you are looking for faint dye traces against a dark background. Any visible purple leakage and you simply cannot see the dye.
Art restoration / document examination — The 365nm bar light provides even illumination across a work surface. Conservators use it to identify repairs, overpainting, and material differences that are invisible under normal light.
Resin curing station — The 365nm strip mounted in an enclosure works for UV-cure resin. Note: resin curing peak absorption varies by brand — most work fine at 365nm but check your resin datasheet for the optimal wavelength.
More use cases and detailed photos: https://zegalit.com
One more thing — we want to get our products into BLF members hands for honest, no-strings-attached reviews.
If you are active here and have experience with UV lighting (fluorescent minerals, uranium glass, inspection work, etc.), reply here or DM me. We will send out a few samples of the 365nm strip and flood light for you to test and report back.
No requirements on what you write. If it is good, say so. If something needs improvement, say that too. We want real feedback from actual UV light users.
We are also open to custom requests. If there is a UV product configuration you wish existed but cannot find anywhere, tell us. Our factory does custom LED strip densities, wavelengths, and form factors at relatively small MOQs.
I see the “which UV light” question all the time in fluorescent mineral and uranium glass communities, so here is a technical breakdown from a manufacturer perspective.
The physics: 365nm is mid-UVA, near the peak excitation for many fluorescent minerals and uranium glass. 395nm is at the violet edge of visible light — your eyes register strong purple from the LED die itself, not fluorescence.
Why visible leakage kills fluorescence: The emitted fluorescent light is orders of magnitude dimmer than the UV source. If your light also produces visible purple, that glare overwhelms the faint fluorescent glow. Like trying to see a candle in a room with the lights on.
The ZWB2 filter — the real secret: Even genuine 365nm LEDs leak some visible blue-violet. ZWB2 is black filter glass: >85% transmission at 350-380nm, <1% at 400nm+. With it installed, the light source appears nearly dark when powered on. Only fluorescence is visible. That is the “magic” uranium glass collectors talk about.
Power is overrated: A 50W unfiltered 395nm flood shows less useful fluorescence than a 5W properly filtered 365nm one. The limiting factor is UV-to-visible ratio, not total wattage. Spend budget on filter quality and wavelength accuracy, not raw power.
Quick use case guide: Uranium glass display → 365nm strip + ZWB2, near-invisible source. Mineral collecting → 365nm flood, wide beam. Yooperlite hunting → 365nm flood. Resin curing → 395nm works fine. Pet stain detection → 395nm works, 365nm shows more detail.
How to verify a “365nm UV” claim: 1) Look for black ZWB2 filter glass (not clear). 2) Shine at a white wall in darkness — visible purple is leakage, not useful UV. 3) Test on uranium glass — should glow vivid green. If dull, wrong wavelength or bad filter.
Full specs and spectral data: https://zegalit.com
Thank you, that’s some helpful information, especially about the ZWB2 filter.
@ZC_Lighting Please carefully read and obey the Commercial Sellers - BudgetLightForum.com rules. As a one-time courtesy I have merged your multiple threads into this single one. From now one please follow these instructions:
@sb56637 Understood and noted. Thank you for merging the threads and for the guidance. We will keep all Zegalit updates, product announcements, and responses within this single thread going forward. Appreciate the one-time courtesy. — Chen
Correction/Clarification: I want to be transparent — our standard 365nm LED strips and flood lights use genuine 365nm wavelength LEDs, but ZWB2 filter glass is an optional add-on, not included by default. The strips come with standard silicone coating for waterproofing. If you need the ZWB2 visible-light filter for maximum fluorescence contrast, we can provide it as an option. Apologies for the confusion in the earlier posts — that was my mistake in the spec writeup.
To be clear about what our products actually include:
  • 365nm UV LED Strips: Genuine 365nm chips, silicone coating (IP65) or tube (IP67), no filter glass by default
  • 365nm UV Flood Lights: Genuine 365nm chips, standard glass lens, no ZWB2 filter by default
  • ZWB2 filter: Available as an optional add-on for customers who need maximum fluorescence contrast
The wavelength accuracy is real — we verify with spectrometer. The filter is a separate decision based on your use case.
I need to clarify something important and apologize for the confusion in my earlier posts.
ZWB2 filter glass is NOT included with our 365nm UV LED strips or flood lights. I was overly enthusiastic in the spec writeup and stated something that is not accurate — that is entirely my mistake, and I am sorry.
Here is the reality: we sell through Amazon US with international shipping. ZWB2 glass is fragile — it cracks in transit, and the breakage rate on long-haul logistics makes it impractical to bundle as a standard component. It also adds significant cost to the BOM. For customers who want it, we can discuss it as a special arrangement, but it is not part of the standard product.
What our products actually deliver: genuine 365nm LED chips, verified by spectrometer on every batch. We bought three competing “365nm” lights and measured all three — they peaked at 380nm, not 365. Ours peak where they should. That wavelength accuracy is the real value proposition.
Again, sorry for the sloppy spec writing. I will be more careful going forward. If anyone has specific questions about what is and is not included, ask here and I will give you a straight answer.
— Chen
By the way — someone pointed out my replies sound a bit like AI. Guilty as charged I think :joy: English is not my first language, so I use a translation tool to help me write properly. If my posts come across as robotic, blame the translator, not me! Maybe I need to upgrade to a better one haha.
Just to be clear — I am a real person, the official technician at Zegalit. I read every post, I understand the tech, and I genuinely enjoy helping with flashlight and LED questions. The translator just makes my Chinese-brain thoughts sound like a textbook.
Anyway, thanks for the feedback. I will try to be more casual.
