Zelee — did you check what Malaysia’s band plan allows power911 to use there?
Power911 — I’d be surprised if your police station can help you much on this, though no reason not to ask. Someone there may happen to know the answers or point you to someone.
You will want to learn both what Malaysia’s regulations say and what agreements the local radio operators have made within those limits — it’s a shared resource plentiful when managed cooperatively.
For example I use a “2-meter” radio often. The regulation in the US specifies a range of frequencies for the 2-meter band, and lets beginner ham operators use that.
Remember I’m talking about where I am in the US — you need to find out how it’s set up in Malaysia.
My local area band plan for 2-meters is the agreement among ham operators on how frequencies within that 2-meter band get used for various kinds of communication.
EDIT: It looks like this: http://ncpa.n0ary.org/overall_2_M_band_plan.pdf
There are band plans for each band. The regulations say what level of license is required for operating on that band. The band plan says how it’s shared.
My local area band plan says how far apart the “steps” should be — if someone’s working on 147.495 mhz, in my area, the separation is 15 mHz — so I’d go to 147.480 or 147.510 to see if that’s free at the moment.
But if I were living a little further south, the separation in the band plan is 20 mHz. So I have to know where I am, and where the person I’m communicating with is, to get it right.
If you’re transmitting in between two accepted frequencies, you produce noise on them, and you hear what sounds like a lot of noise from the people using the accepted frequencies. There’s some “spread” around the specified frequency. Cheap radios generally are worse about that. You need to look up the reviews of the radio, and know your local situation. As with anything else, you can probably buy anything you want mail order from China, and it won’t necessarily be at all suited to your needs, since they won’t know what they’re selling.
Ask locally.
Let me tell you an anecdote about why it works this way:
An idiot I know bought a couple of ham radios — without passing the beginner test to get a call sign and license — ’because “Freedom!” he said — and he was using parts of the band set aside for repeater operation, or for moon-bounce, or for morse code, or for digital radio, or for other satellites including communication with the International Space Station (yeah, you can do that with a ham radio if one of the astronauts or cosmonauts passing overhead happens to be available). And that idiot was trying to teach someone how to fly an aircraft, and ended up screaming at everyone else to stay off “his” channel so his student could hear him. Caused an emergency situation. Could’ve gotten someone killed. Had no clue how far his signal propagated or what machines or relays were causing “noise” on those bands he was trampling through.
EDIT:
Those of us who heard him ranting about this at a party tried to straighten him out — because it’s our issue, first. If he kept screwing up, the FCC would find him eventually. Better it doesn’t go that far.
I don’t know how the rules of the road work in Malaysia — but I expect that most traffic stays within lanes and turns as expected and that occasionally you have someone who decides to go against the traffic.
That kind of interference happens unless the radio bandwidth is shared. Freedom doesn’t mean screwing up a shared resource.
