Ok, here’s my story and I’m sticking to it.
Order placed 4-19-2016. Arrived 5-2-2016. Shipped Air Parcel Register.
I ordered 4 COMETA’s, 1 for me 3 for friends and family.
They were packaged well and arrived in one piece with no visible damage to boxes. Each light is packaged in a cardboard box with foam cutout insert. Very good protection.
3 lights arrived with no problems and in working order.
1 light had a bad silicon switch boot, probably ripped in initial installation. About 1 inch of the O-ring in front of the lens was not in it’s groove. The light will light but jumps back and forth to different modes. [ I’ll try to diagnose this tomorrow.]
I completely disassembled each light, took the pill out, took out the driver retaining ring where driver was loose, checked the wires for cuts or abrasions and none were found so I did not unsolder the wires.
I lifted each MCPCB and thermal compound did not seem to be enough so I applied Artic Silver 5 under each MCPCB. I then reassembled the pill by installing the driver retainer ring.
I disassembled the tail cap, that is when I found the compromised Silicon switch boot.
I cleaned everything good making sure to remove the few aluminum chips that were left from the machining process. lubed the appropriate places and reassembled.
Tailcap reassembled also with new switch boot.
I also put Kapton tape over the solder points on the LED board.
Then made plastic washers from a milk jug and covered the bottom of the pill.
Installed battery, 3 lights worked properly, 1 did not…. yet.
Observations:
Wire: All had 24 AGW wire
MCPCBs: 3 had KRONOS BLF _ 1 had Noctigon
A few things were loose & not tightened completely also.
I did cover the + & - solder points in the front with Kapton tape & from what I saw … why not? It is easy to do.
I also added one of these:
XP - Plastic Butterfly Style Emitter Spacer / Insulator
It makes centering the LED simple and makes no difference on focus that I can tell.
I would recommend that each person take their light apart and check it and clean it up good. Re-lube it and put it back together.
It is easy, just take it slow and don’t force anything when reassembling.
Put the bezel end face down on a magazine or mouse pad when you unscrew it. Leave the lens in the bezel right there. When you reassemble just screw the light right back in the bezel.
Oh yeah, somebody mentioned earlier in a post that the tail switch was real sensitive. All mine were to the extreme.
You can fix that by taking the tailcap apart, turning the silicon boot inside out and cutting about 1mm off the little silicon “plug” that will be sticking out when it is inside out.
It is so sensitive because the switch already had some ‘pre load’ on it from the tight fitting boot. This will solve that.
Someone posted a video somewhere in this thread that showed how to disassemble the COMETA. For those that need it it shows each step.
If you can use a knife & fork… you can do this.
Just take your time and DO NOT force anything. Then all will be well & you should have a harmonious outcome.
Oh yeah, I just took this thing outside…. IT IS A BEAST!!!
