Warsun CT9S
Includes everything in pictures in link, lanyard, 2 extra o-rings, GID green tailcap cover, extra tailcap switch, extra lens, and nice padded box. Deeper reflector than C8, nice threads, stainless bezel, will tailstand, anodizing equal to Concoy, and driver held in by screw down retaining ring.
Master switch at tailcap, side switch to change modes but can also turn light off by holding down a few seconds. As long as tailcap switch is turned on the side switch can also be used to turn light on. Last mode memory on both switches. A steal at $22.78 with “wallbuysallmagic” coupon although I got it even cheaper with the now expired “tffwallbuys” coupon.
Edit: The reverse clicky tailcap switch can also change the modes.
Is the spare switch a different(forward/reverse) one?
What happens if you switch it off on electronic switch and then off at tailcap and then on again at tailcap? Still switched off?
Tailcapcurrent?
This…looks nice. Just different enough from a C8 to actually not be nauseating to look at ( ) and cheaper than the Convoy L4. Good utility light once that lanyard gets a nice lobster claw to replace the thread, be nice to see the driver. (I still have 4 trimpots waiting for homes )
1>Don’t know how to tell the difference between forward/reverse without it being hooked up, feels just like the one on the light which is a reverse clicky. Edited my original post to say that modes can also be changed by the taicap reverse clicky.
2>No, the light comes on.
3>Can’t seem to get my meter on the right setting. Have a Fluke 77, explain the correct setting and lead hookups on Fluke and I will check.
Doesn’t come on with a fully charged battery, might come on when the battery gets weak, it looks like it could light up as it seems to be transparent rubber.
You know what though, I was thinking of how this compares to the Convoy L4 and realized that while the L4 may fit into a C8 holster, this likely is too long to make the same claim.
Up in the text box toolbar, there’s the earth with the chain link, the two frames of film, and then the little landscape icon. Click on the landscape icon and you’ll haave a few options. The second line is ‘Relative width’. Enter a number 1-100 and it automatically scales the image so that the width is that percentage of the page wide, but remains proportional.
The anodizing looks pretty good, like you said “similar to convoy”. Thanks for uploading the pics. The length looks about the same as a Crelant 7g6cs. Is the knurling very deep or grippy?
I’m pretty meh about mine. The tailcap is over-engineered and the driver IS put in it is flickery and likes to sometimes go into low-voltage protection on a fully charged cell. The light looks fantastic though, no denying that.
