This Light was provided by TomTop in return for my review (thanks Cathy).
I failed to mention a few things in the video, first the lens IS glass (although not AR coated) and the reflector IS aluminum and has a very nice finish in it.
Second the side switch also activates “standby” mode (hold down 2 1/2 –3 seconds)which lets you simply press the side switch without fully turning off the light, and a quick press will turn the light back on in the mode you left it in. You have to use the tail switch to fully turn the light on or off.
The anodizing is not listed on TomTop site but after looking else where it seems that it is HAIII anodizing on the light, it does have a good looking finish on it.
I also did a spring bypass on both the driver spring and tail spring with marked improvement, it went from 2.17 after stabilizing (30 seconds) to 2.46 after 30 seconds.
Price at time of this review $18.86
The rest in the video and manufacturer listed specs below.
Specifications:
Brand: Warsun
Item Color: Black
Material: Aircraft-grade aluminum alloy
LED Type: CREE XM-L2
Light Color: White
Lumen: 2000LM
IPX Grade: IPX-6
Flashlight Mode: High, middle, low, strobe and SOS (Press switch to change the light modes.)
Battery: 1 * 18650 / 1 * 26650 (Not included)
Item Size: Approx. 17 * 4.7cm / 6.7 * 1.9in
Item Weight: Approx. 240g / 8.5oz
Package Size: Approx. 17.5 * 5.2 * 5.2cm / 6.9 * 2.0 * 2.0in
Package Weight: Approx. 275g / 9.6oz
Usage:
Press the middle button for about 2 seconds, it will go into stand-by state with indicator in blue.
In stand-by state, press the middle button twice in rapid succession, it will go into high-mode lighting.
When the battery is in full condition, the indicator appears blue, and when the battery power is low, it will flicker.
In stand-by state, the flashlight uses some of the battery power, so if you don’t use the flashlight for long time, please press the tail button to turn off the flashlight or take out the battery.
. The freak'n guy (supposed owner of Warsun) was defending it, saying his "engineers" know better, etc... He was a real character... I don't think they got rid of the pill top depression in the middle though. Other lights have that as well - hard to find properly machined pill tops though, and I'm not sure it's not as bad as I used to think, because a copper MCPCB still can have pretty good surface contact even with a center hole/depression, not ideal though for sure though.
