I received the light! Very quick!
My impression:
Setting the date & time is horrible.
I got it as far as setting the time, but before I’m able to set the correct date the screen already turns off again and I have to start all over. Tried it several times, tried to recharge the device to see if that was the problem, but it’s still nearly impossible. Looks like button isn’t always recognized, despite hearing an obvious “click”
If you want to know the time you´ll have to click the button, screen turns off after 2-3 seconds.
During the charge there is no way to see it is charging, or to know when it is finished charging.
The light has High Low strobe & sos. If you need lo you first need to click it on in HI. It is HI-LO-Off
Strobe is accessed by holding down the light button, and sos by holding time&light button, so no accidental activation.
On High and Low it shows the remaining usage time. 1:40H for Hi and around 8H for lo (manual claims 1.25H for Hi and 4 hours for lo)
For the short period I had it on me it didn’t annoy me. It’s not heavy, and 5 minutes on hi didn’t make the light very warm.
Manual claims 200 lumens on high, 60 on low. No accurate way to confirm this. I think it might be a couple lumens off.
The light has more throw than flood, it has an ugly purple color and an ugly semi-square beam pattern.
Picture taken with cellphone on auto settings
When having the light on the inside of your wrist the light does not shine where you would want it to shine. The little bit of spill does shine on your fingers, but when in very dark environments I guess the hotspot shining on your other hand is more blinding than the spill helps.
If you use it to light the way you’ll have to hold your arm stretched out in front of you, otherwise you’ll light up the side instead of the path in front of you, so a normal flashlight works better in this situation.
All in all this light might have it’s uses, but I’m not seeing them right now.
I’m not unhappy I bought the light, for the price it is a nice gimmick to own in the collection, but for practical uses I doubt I’ll ever use it.
All in all I rate it:
