That may be a difficult road to follow if the sale is a one-off event, once someone comes up with a how-to the sale is gone. The best thing to do is making sure you have all the sizes of the collar and lens and the correct distances, and start searching for the right host and hope for the best.
The UF1405 or 1504 does seem like a good choice. Inexpensive and big enough to be a real super thrower, but the lens might not have the correct f number. From what I recall the f/D might be a bit under 1, which means the outer part of the lens would not be used when used with the reflecting collar. But maybe it’s close enough to 1 to not matter.
I understand, I sent kiriba-ru a message to see if he is interested. I don’t necessarily need to see a finished product but at least a good parts list and some users that may be willing to help if needed. Just want to be sure this can be done by a modder who is confident in assembling lights but no access to fully custom or more advanced machining. Assembling, reflowing, small tweaks (sanding, filing, maybe a dremel at most)…
Machining such collars is not a problem.
Im not sure it will be easy to make mirror finish with available for small quantities technologies.
Most reflectors (not only about flashlights) are plastic, they are made with steel mold that is hardened and polished so surface that need to have mirror finish cames almost perfect. With any electro-plating mathod coating layer repeats any defects on surface.
It has only 29mm inner thread diameter. This is the maximum diameter over the LED to fit the collar.
Pill is too deep (like the UF1405/1504) and the outer pill thread diameter is even smaller than 29mm.
The pill has enough top diameter for the collar. I would suggest completely doing away with the whole emitter cavity (11mm deep, by the way), and just leaving a ∅20×≈2mm trench on top for the emitter board (trench depth to be discussed). This would also allow a deeper driver cavity. However, since the emitter would sit 11mm higher than normal we would also need to devise a way for the head to climb up 11mm higher.
My personal superthrower "The Sceptre" uses a Mag host with a turbo head. The collar will fit on top of a Mag heatsink slug, and the head threads / heatsink height can be used to fine tune focus. I would recommend that type of host for anyone considering a build with a wavien collar.
The GT is another excellent candidate for a collar. The Optolife lens is close to fitting but not perfect. With today's 3d printing technology, it is just a CAD file and a 3d print job away from existing. I think a design could be developed to allow anyone to print the mounting system which mounts the Optolife lens securely in the GT at the correct height. There would need to be a bottom piece to center the lens and hold its height relative to the LED, and a top piece that is secured by the bezel and holds the top of the lens securely. An additional piece to space the collar from the LED and center it is also needed.
Here is the lens they have:
It is 50mm, with an EFL of 50mm, and a BFL of about 42mm. It will be $35, so pretty decent price.
“we would have no problem selling the matching 50mm F/1 aspheres also. We have those custom made, so the more we can sell the better. It is difficult to find good imaging F/1 lenses on the street. Because these have very good imaging and tolerances, they too are somewhat expensive”
The response was good so the deal for the collars is going through I will make a post when I get the link/code to buy.
Thanks to all you guys who are true enthusiasts, this couldn’t happen without you
Yeah, I will put all the details together in one thread tomorrow when I get the purchasing code.
They will ship from within the US, so it should be pretty cheap.
Free shipping if you spend over $100 too.
LOL, I’m sure moving around stuff within the US is cheap but to get it out of the US with reasonable shipping costs is the challenge, and I’m sure that spending $100 will not get me free shipping to Europe.
