Received mine too. Nice light even just stock. I’ll probably just fast the MCU and swap out the U2 1A because I want it for a dedomed thrower. Thanks Simon
Ordered mine around the 3rd of May, stuck on origin post for 16 days then yesterday it’s within 30miles of my house and today out for delivery just arrived while I was typing this. Looks like they use a rarely updating tracking, but then again I wasn’t really expecting tracking on such an inexpensive item.
How many 7135 chips is the best in your opinion?
I was thinking 4 to get 1.4A which gives a good amount of light but not too much heat. Am I wrong on that last point?
Can you run the light on high continuously without problem?
Just got two orders from convoy-flashlight - s2+ and s8. I really like S8, S2+ is awesome too but for some reason I don’t like tail switch. Sometimes it’s hard to switch it on/off with a thumb. I guess I will have to take it apart and take a look on it. I hope it can be fixed. Otherwise price and quality (other than switch) is great.
Thank you.
The convoy S8 has also the switch on the tail cap. I don’t understand. :S
About that turbo mode. Instead of using a timer, wouldn’t it be better to use a temperature sensor? That way you can use turbo as long as the temp is below a threshold. I’m sure that some micro controllers have built in temp sensors. Or not?
Temperature sensor would be cool, but then again, timer works well enough. And if you want to use it as a hand warmer, you can always click it back to turbo with a single click. :)
I know. It feels like there is something wrong with my unit but that should be easy enough to fix.
Yea, temperature sensor would be awesome. I don’t like a timer because I often use my lights on bike and then heat is not an issue but that IS a problem when someone else take my light.
In almost every situation I use max output. The only time I back any light down is too much heat or if I’m working in really close quarters.
Mine is the same way. Really weak clicky like they used too long of a spacer or the wrong boot or something simple like that. It shouldn’t be difficult to fix. Apart from that though it is perfect; I love this little thing, easy to see how so many use it as an EDC.
After playing with mine more, the clicky is a bit hard to press on mine as well. I opened it up and found a metal washer (one that looked really beat up and had rust on it... not sure what that's about). I replaced the washer with a new one and tried putting in a forward clicky from IOS, but it was physically too long and prevented the retaining ring from screwing back on. I've gone back to the original switch for the time being.
I found a thinner washer to replace the thick, beat up, rusty washer that came in it. I kept the same reverse clicky. With the thinner washer, the clicky is much easier to operate.
Thanks for the tip. I didn't have a thinner washer on hand but figured it would help. It feels like there's a gap between the top of the clicky switch and the rubber boot. The forward clicky that I tried is longer, but too long. I'll check the hardware store sometime.
Definitely a gap between the boot and switch on mine. I’ve got a few different boots that have larger solid rubber contact points that should do the trick. They over tightened the crap out of the retaining ring on mine though. :\
