Payment sent via PayPal, thank you.
Regards,
Patrick
Regards,
Patrick
pay pal sent thank you Simom.
What are the expected output levels for this combination?
7135*4
XML2 T6-3B
Thanks
Dead Goat
Anybody know what TIR would be a perfect fit replacement for this S2+?
I know with 8*7135 at approx 50% PWM it is still quite bright, remember Cree LED’s work more efficiently at lower currents…
For the $11~ you paid for your light you won’t be diassapointed…and it shouldn’t heat up all that much, you are only pushing approx 1400mA to the emitter
If the reflector is one of the deep ones there isn’t a perfect “dropin” you would have to build up under the emitter to make the pill thicker in order for the battery to have contact
If it is one of the short ones 13mm reflectors then the 21mm TIR’s should fit
These should fit nicely
https://www.fasttech.com/p/1574902
https://www.fasttech.com/products/1606/10002020/1187501
There is a solution to those that want brighter high’s, and lower lows and have battery protection
It involves loading special firmware
JouhnnyC’s Star V1.1 has the ability to run wide open, then automatically step back to a lower level
I have a Convoy S5, I have it set to have hi>lo, moonlight, and memory (I have been rethinking the memory function as I like it always to start in hi) by soldering stars 2, 3
It has 5 levels, wide open for 2 minutes with automatic “timeout” and fallback to approx 50% power level as the high level, all the way down to a moon mode that is incredibly low yet still useable
turbo w/ 2 minute timout, high, med, low moon
What he said....
thanks ....
I just ordered mine yesterday, so I have no idea height/width the stock reflector is. I am wondering if anybody knows a plug-n-play TIR, as it would be nice to just drop it in and call it a day. Not trying to stuff copper under the LED, but if I have to, I guess that's always an option
S2+ ordered, paid with PayPal, forgot to tell the color I want..
I want the Gray and 3B emitter.
One S2+ shipped ![]()
you are welcome roberta! Hope it made sense to you and you were able to make an informed decision from it. Just sharing what others here have shared with me.
good day to you as well….
patrick
Just ordered an S2 with 7135*8 and XML2 T6-4C for $13.37 .
Excellent deal . Thanks Simon .
TQ Simon. Just send payment with paypal for order no. 61930756402721.
You don’t need to make order via aliexpress if you intend to pay via paypal, that is just making mess in your and sellers account on aliexpress…
Can you check my order 61920907923239. I left message to change to 7135*8 and t5-5b emitter in the original order and my email doesn’t show it
Thanks Simon
Hi Simon.
Paypal payment (Transaction ID # 8XW265215N378490) sent for 1 unit grey Convoy S2+, standard configuration.
Thanks!
Thanks Simon
uhmmmm,i didnt see any message,
but i will get your parcel back from the post ,
it’s almost sent out
dont worry
but if customization,$4.56 will be added
pls click the following link ,and order 456pcs
http://www.aliexpress.com/store/product/0-01USD-checkout-link/330416_1803382214.html
Hi Simon,
I just sent you $11.09 via Paypal for one grey Convoy S2+.
Stock version, no changes.
Transaction code: 4HJ79122G4505590J
Thanks for the offer. ![]()
HQ
Hi Simon,
Stock version, no changes.Transaction code: 4HJ79122G4505590J
HQ
ok ,received
Ordered a stock black one through your website. Darn it, I knew it was a bad idea to browse these forums again. ![]()
I have the S2+ and an S3. They have the same size reflector, and it is much shallower than the reflector in the original S2. I put this TIR in my S2+:
Led Lighting,Visual Comfort Lighting,Low Voltage Landscape Lights
The outer holder was just slightly too wide to fit in the head. I cut just the outermost part of the holder off. The rest of the holder still works as a cup, holding the TIR at proper focus. The result is a broad, even beam. The beam is noticeably brighter with the TIR than it was with the shallow reflector. The TIR allows very little spill. I greatly prefer the TIR over using the shallow reflector in this particular light.
Another thing to note about the S2+ is that it’s pill is taller than the pill in the S3 or original S2. It appears to be the same diameter and thread size as the pill in the original S2. The pill in the S3 is slightly smaller diameter.
