T2 is a compact portable LED flashlight, using 1 18650 Li-ion battery or 2 CR123A batteries, full power output mode 1,730 lumens, 42,450 candela, throwing 412 meters, there are three brightness modes, full power output mode is suitable for short-term emergency use, The medium mode is suitable for outdoor, and the low mode is suitable for indoor or close lighting. The T2 light head adopts Weltool's patented T-HC (Through-Hole Cooling) structure, which releases the heat generated by the LED and electronic components from the light head to the environment in time through air convection. The bezel is made of stainless steel with attack teeth, which are wear-resistant and drop-resistant, which can effectively protect the flashlight head. T2 has a mode memory function, and has reverse battery protection, low battery reminder function and battery over-discharge protection function. It comes standard with a stainless steel pocket clip, which is easy to carry. T2 has strong performance and simple structure, and can be used as emergency equipment carried every day.
Weltool T2 uses aluminum alloy reflectors with high reflectivity, high temperature resistant LED gaskets, Luminus SFT40 high-intensity LEDs, stainless steel Abrasive blasting bezel, through-hole cooling structure, not only these, but also ultra-low internal resistance forward switch, can handle 10A current, low internal resistance phosphor bronze spring,high drain 18650 battery.
The flashlight has battery over-discharge protection (when using lithium-ion battery), battery reverse connection protection, low voltage reminder function, memory mode function.
No flicker and noise
Patented through hole cooling structure
Battery type: 1 high drain 18650 lithium-ion battery or 2 CR123A batteries
Weltool T8 and T8Plus flashlights share the same light head, but the body and tail cover are different. T8 uses 1 18650 battery or 2 CR123A batteries, and T8Plus uses 1 21700 battery. This head adopts Weltool T-HC through-hole cooling structure, built-in high-density high-power LED, full power output of 2,100 lumens, 94,000 candela, and a throwing distance of 613 meters. There are 4 modes (low-high-medium-full power) to meet different usage needs. T8 and T8Plus are compact in structure and come standard with stainless steel pocket clips, which not only have strong long-range shooting ability, but also have a large lighting range with Strobe, especially suitable for outdoor exploration, tunnel work, rescue, inspection, etc.
The W1 is a throwing LEP flashlight with a spill, with a head diameter of only 29mm, a high mode of 175,000 candela, a throw of 836 meters, 630 lumens, high and low modes. The light head(LH10) adopts a customized LEP light source and an innovatively designed optical lens, which optimizes the traditional LEP flashlight beam into a beam with a spill without additional filters, which is the first of Weltool. The front end of the light head has a stainless steel bezel and a thickened shell, which is wear-resistant and anti-drop.
W1 has a battery polarity protection function, a low battery reminder function and a battery over-discharge protection function. It comes standard with a stainless steel pocket clip, which is easy to carry. Tail forward switch with shock-resistant, anti-fatigue, low-resistance spring structure, comes with a high drain 18650 battery. The W1 is a groundbreaking tactical flashlight for special tactical needs.
The W35L and W65L are long-range LEP weapon lights with spill beams, the W35L is the compact (18350 battery) and the W65L is the full size (18650 battery). Shared LH18 head, light intensity of 175,000 candela, throwing distance of 836 meters, 630 lumens. The light head adopts a customized LEP light source and an optical lens innovatively designed by weltool, which optimizes the beam of the traditional LEP weapon light to have a spill beam, which has a larger visible range and will not interfere or expose the position of teammates due to the spill. The rear of the W35L and W65L is a forward switch, with a shock-resistant, fatigue-resistant, low-resistance spring structure, and comes with a high-drain 18650 or 18350 battery. This is a groundbreaking weapon light that optimizes the LEP traditional beam to a spill beam pioneered by Weltool.
Weltool T2 - very good looking light with absolutely no information about the UI, not to mention lack of simple battery level indication. Sorry if I’m picky but it’s 2022.
Looking at 21700 to replace my 18650’s now. Brightness is at the point of diminishing returns, I’m more interested in being able to maintain power for longer.
