You can savely use Enerpower 26650 in Series. They are protected and made in Germany. They have a very high capacity and the Voltage stays very high under load.
If your order flat-top KK ICR's from FastTech they will most likely send you INR's as they did to me twice. (See this thread.) It appears they ship INR's for flat-top and ICR for the button-top. You'd just have to carefully add a solder blob to the top of the cells.
I would personally prefer to run protected cells in series, which is going to mean icr chemistry simply because inr cells are not sold with protection circuits generally.
safer chemistry is not going to help with reverse charging, which is the main worry with series wired cells.
The enerpower cells are supposed to be extremely good, I definitely want some at some point, they have 7 ish amp protection circuits and a ce mark. you do pay the price though.
I have 4 MNKE I run in series. I just keep an eye on voltage and always balance charge them. I have 4 Keeppower but they are like 70mm long and will not fit what I needed.
