I am looking for screwdriver precision, researched the inet and found 1 interesting sets, do you have similar ones and what’s your experience with them?
Features:
32-in-1 interchangeable precise manual tool set.
Professional portable hardware tools.
Light weight, compact design.
High hardness and good toughness.
PP&TPR material, non-slip handle.
By using this set of tools, you can remove the small part of your cellphone/computer/Mp4…and repair the device without damaging it.
Product Description
Item Description
100% Brand New
Type : JK 6032-A
Handle Length : 105mm
Head Length : 28mm
Package Include (for one set)
1pc Driver Handle
1pc Tweezer
30pcs Screwdriver Bits
For that money you can’t go wrong have bought a set on DX many years ago when they were called DealExtreme only and that has the most bizarre bits like triangular etc etc and a lot as well. Do not use it often but when needed I am happy to have it.
Then I have a set similar to what you now show and that gets a lot of use
Most I use my mannesmann bit set, the bits are not for precise work though some will do, this is more for real DIY work. It had 25 years warranty and I bought it when doing some serious work at home and cheap bits were failing. Got it 14 years ago and all bits still work like a charm.
The rest of the mannesmann tools are rubbish after the very nice quality bit set I thought wow this must be a quality brand and while browsing for drills they were not expensive so I ordered three different drills (a normal, 1 with stand for precise drilling and on of those heavy duty for demolition work. The normal twist to open and close front is now crooked and it won’t go to hammer, the precise one is vibrating to much to actually be able to drill precisely though the stand works (using the normal in it) and the hammer does bkt turn only hammers after drilling.two holes in concrete and all the bits they put in the cases are absolute rubbish)
yeah I would avoid this tool set!
the driver handle is made from old cheese :disappointed:
Lowes has had fairly decent sets under the Kobalt branding on sale for a couple of bux more.
the handle is the thing I look at on these magnetic sets, the bits will be OK to get by.
clearly at 3-5 USD price point yer not really after the “best”. :money_mouth_face:
> Brand 32 in 1 Magnetic Screwdriver Precision Screw Driver Tool
Bought that exact thing a few years ago.
It’s flimsy, imprecise, and the tools bend very easily.
It was worth the $3 or so it cost, but you have to assume you’ll replace any bit you use frequently with a good one later.
