I should have thought of this from the beginning.
I should have asked OP what his minimum charge rate per slot is. It would have narrowed things down.
It might just be differences in our use cases.
Batteries last me quite a while, I mostly have 18650s and 21700s as well.
Can confirm, have done it. 21700 fits too but is uncomfortable in the length department, and probably longer 21700 cells (like protected or whatever) wonāt fit.
The $80 black Friday sale I got mine in was amazing.
@vestureofblood
According to this post, the Vapcell S4+ can charge three 26650 cells at once.
I know thatās not exactly what youāre looking for, but itās somewhat close.
If weāre talking about just loose cells ya I go through about the same. I donāt think 2.5A or 3A have ever even been used once on my charger.
And then I put that battery in a flashlight, set the thermal ceiling to 70Ā°C and hit turbo lmao
The irony isnāt lost on me lol. A 25A+ fast discharge is way more damaging to a battery than a 2.5A fast charge. Idk why I do it, maybe ocd.
In Auto mode, once you insert the batteries, it starts charging at the current you had already set for that slot. For example, I have one slot @ 500mA for 14500 / 18350 and 3 slots @ 1A for everything else. If you unplug it, the setting is erased.
I typically use manual modes on chargers, but not on this one because I have no need to set other termination voltages.
You guys have no idea how helpful you really are!!! Thank you.
Happy upcoming or belated Birthday Mr.Matt Scorpio!
Hope we helped FWIW, I charge my 26650s at 1A, and yeah it takes a while. The format is on life support, not much innovation happening outside the EV formats. I have a few Vapcell K62s, Orbtronics which are wraps of something, etc. They tend to have higher IR. If you charge at 2-3A, and the voltage is above 4V, the chargers are often finicky and just go straight to done.
Let us know what you choose!
Wellā¦ The Folomov COULD have been an epic charger. It comfortably fits 4x 26650s, the springs are sturdy, it charges at up to 3 amps per cell (2 amps each with 4pc installed). The display gives all the relevant info like voltage and charge status.
However there is one glaring Achilles heel about it I didnāt realize. The charge current has to be set for every cell every time or it will default back to 250ma. I donāt see anything in the instructions about how to fix that either.
That is like going to all the trouble of building a hot rod car and then filling the engine block with water instead of oil. That way no one can accidentally drive to fast with it, and it will be āsafeā.
I was so excited when I opened that box thinking I had found a powerful solution.
Will the miboxer c412 retain the last used charging current, or does it just default to the automatically detected ābestā for cell? If it defaults to auto what current do you get when you pop in a 26650?
