What Chargers fit 4 or more 26650s side by side?
I need to find chargers that can fit at least 4x 26650s side by side all at once. Not just two 26650s and two 18650s. One that could charge 6 or 8 26650s all at once would be even better.
So far the only thing I see is possibly the Xtar Dragon VP4. Is there anything else?
Although this wont help you because its not made anymore, the Miboxer C4 Plus. Plus only, the non plus wont do it.
I have both plus and non plus.
Link:
Miboxer C4-PLUS 4 Bay (Super Fast) Li-ion Battery Charger-ORBTRONIC
You can still get the mi boxer C4-12 on Amazon.
I just received two on Saturday. I had trouble getting the link on here without revealing my personal information. Just Google it.
The Gyrfalcon All-44 and All-88 will fit 26650s in all bays at the same time: 4 or 8, respectively.
That’s true. I am not sure if OP needs them all charged at two or three amps which the chargers you mentioned cannot do.
Here is a screenshot without my personal information.
Every time I Google the mi boxer charger it comes up to my Amazon account.
Will that fit 4 x 26650 ? I know the plus did.
These are great chargers.
Yes… but if you have all day to watch it charge at 1 Amp Max then get it.
Its Charge current is out dated.
I meant the miboxer C4-12.
I forgot to mention the SkyRC can also charge all four slots at 3 amps and fit 4 X 26650s. But it costs way too much. $100.
Yes.
The Mi Boxer C4-12 can accommodate 4 X 26650.
That’s why I suggested it to the op. Not only accommodating 4 X 26650 , also can do them at 3 Amps.
Ok thanks, I may be signing up for one of those.
You’re welcome.
I thought of another one.Folomov A4 updated version can handle 4 X 26650 and 4 X 2amp.
The problem was with the display eventually it faded and you couldn’t see it.
Illumn sold it. I checked recently and it was over $60 with shipping. I think it was closer to $66. Between that, fading LCD display and 2Amp per slot…a no go. I can live with a two amp per slot but not the defect and the cost.
Seeing some great options here gang. I’ve looked at the Gryfalcon chargers before. Only hiccup with those is it appears you have to manually start the charge on each cell every time, is that correct?
I think I will be giving the Folomov A4 a try. Looks like the 26650s would fit pretty comfortably in there.
I’m open to trying several if people have more ideas.
If you’re ok with a larger size, the Xtar VC8 can fit 6x 26650 or 8x21700
It can also be modded to work with xx800 cells, I use mine to charge my 26800 cells, though they’re a tight fit.
Yes. But you need to be very very patient. It only charges 0.5 amps.per slot when charging 8 batteries.Only 1amp for 4 slots, 2 amps for 2 slots.
Kind of useless in my book. I checked out all these chargers a year or two ago and none compare to the Mi boxer C4- 12.
I hope you have better luck with the Folomov than I did. I actually returned 2 of them for Displays that faded and disappeared. Iirc it was less than 6 months.
Ilumn is great, they took care of me as they always have.
I have the VC8 it is pretty good, I rarely need to fast charge more than 2 batteries, for the rest I can wait just fine.
IIRC there’s also the newer VC8+ which has DC-in and can charge with slightly more power.
You need to charge 4 26650s at once?
What about 4 xtar sc1’s loosely taped together? Lol
You are very patient.:blush:
I charge b/w 10 to 15 batteries per day. Mostly at 2.5A or 3 amp… High drain.21700’s…P45B,50S,40T and high drain 18650…P28A, VTC5D ect.
