DeOxit d5 is wonderful stuff, for its intended application, which is removing oxidation from mating conductive surfaces inside connections.
I only liberally spray when I am in spray and pray mode, that it might somehow work its magic and revive some failed product, which has sometimes even worked.
I would worry it can eat glue, and getting it one ones skin, cannot be a good thing.
It might also swell or degrade rubber parts.
Deoxit has a 'Shield' product, intended to keep clean/cleaned ed pristine connections from oxidizing. I have found this product swells the silicone accordian style weatherproof boots on automotive connectors making them very difficult to reseat at a later date..
I also generally clean things with Isopropyl alcohol. Threads get a light coat of dielectric grease applied with with a normal Q-tip. This is also a great cleaning method on surfaces where future bonding is not a concern. Silicone grease should not hurt O rings.
Circuit boards exposed to the elements, such as computer fans in damp salt air environments, that I never intend to touch the components upon, get a coat of clear nail polish and perhaps Amazing goop to cover where the wires enter the hub's circuit board which has been the failure point of 80% of the failed fans in my experience.
I'd recommend against the Deoxit spray products in favor of their applicator products for most applications, They have other non aerosol products which come with a small brush or just a tube that one can put a drop on a precision swab, such as these:
https://www.amazon.com/Tamiya-Craft-Cotton-Round-Xsmall/dp/B0026IBC2O/ref=pb_allspark_dp_sims_pao_desktop_session_based_4/130-5392058-6324902?pd_rd_w=DfLXg&pf_rd_p=e896123b-6614-49c5-873e-d532e726c2f0&pf_rd_r=KW6ZKY5CPE73SBF7P189&pd_rd_r=ec70d1ec-f39c-40b9-a8f0-9a5e5cafbbd2&pd_rd_wg=mj9yb&pd_rd_i=B0026IBC2O&psc=1
These ^^ can fit inside USB-A and almost always come out gray or black on older USB connections never before cleaned, or inside 3.5mm stereo mini plugs which crackle when the plug is spun.
I also like the following for cleaning inside very small connectors with Deoxit, or applying Deoxit D5, d100, gold or shield, and I use them for applying paste flux as well.:
https://www.amazon.com/Dentek-Slim-Brush-Cleaners-each/dp/B00GD3BTG2/ref=sr_1_9?keywords=dentek+brushes&qid=1645676345&sr=8-9
The DeOxit D5 and the above application products on my 30 year old vehicle's sensor connectors, made the throttle pedal feel like I removed 500lbs of weight from the trunk.
