A nice 5000K.
A dual color temp ramping C8 Triple
Here is a proof of concept on the bench
and in action in the final light. I have since fixed the ramp since there is a tiny overlap between the two channels and it looks a ton more natural.
I think this video has the correct ramp in it. I made it for those unfamiliar with Crescendo
Staticz, nice build! But i canât access your links
Plus one.
These should work
Awesome! I wanted to build something like that, triple with 1 red emitter and 2 white emitter. What driver did you use? Could you give some detail please? Thanks.
This is a âCWF Dragonâ which is a FET+1 but instead of combing the two channels it has a separate pad for the 7135s. I then customized Crescendo where the ramp of the two channels isnât completely parallel and the 7135 channel ramps up and then off then the FET channel ramps up and max. There is a couple frames of overlap between the two channels as it looks a bit odd with the hard switch to the FET channel from the 7135 and vice versa
In the process of changing the LEDâs in a Tiny Monster TM16, took some fitting of 4 individual 20mm MCPCBâs and then I got em glued in with JB Weld (out of Arctic Alumina Thermal Adhesive) So tomorrow I will wire up the 4 XHP-35âs in parallel and see where itâs at. Should be considerably brighter with a tighter beam profile from the HI style 35âs. I aim to try keeping the thermal resistor in there somewhere so the stock driver functions as intended, will see how that works out.
I did this once before and was seeing around 7200 lumens, the TM16 comes with 4 XM-L2 in series so replacing them with 4 XHP-35 in Parallel actually works out pretty well. (or it did before, hope it does again. lol) In stock form with the XM-L2âs itâs making 4170 lumens with a semi-large hot spot.
Being forgetful as all get out, I had the MCPCBâs fitted and glued in before I realized they needed emitters on em. Sure would have been tough re-flowing the 35âs onto the bare boards after the JB Weld set up! lol :person_facepalming:
Yikes!!! :smiling_imp:
Quick and dirty inspired by djozz:
Itâs 8 gauge solid copper âwireâ
Tested w/ a LED4Power 12A driver and got 11.5A - I think thatâs accurate enough?
Since I have to help my Aunt in the morning, I got the TM16 assembled this evening. Quad XHP-35 up and running, thermistor has glue drying to hold it in place. I really donât enjoy soldering leads on those tiny things!
I have Convoy XP centering rings on the MCPCBâs at the moment to help hold pressure down onto the still setting MCPCBâs, those will either have to be shaved or removed to get proper focus so I know the beam isnât correct as it stands, but it sure is bright! Iâll try it in the lightbox before I go to bed, give the dollop of JB Weld some time to set up on that little thermistor before I upend it into the box.
Ow the famous Dragon as I predict⌠unfortunately Charles didnât sell single driver, 5 driver per lot which is very expensive. Very nice job anyway, and definitely sound complicated .
Simple build, Sofirn C8F, XPL HI V2 1A and TA driver with NarsilâŚ
Nothing extreme here but this host is a real bargain at $13 (spent twice that money into the components) Considerably brighter than my X6 with triple XPL. Probably selling this one when the 21700 version releases.
Modded a glaree E03 with a 5700k 219b. The tint was ugly. I dedomed it and lost some of the phosphor but it looks fine (for now)
Before
After
Lost phosphor
!{height:300px; width:200px}https://i.imgur.com/P8A7nJG.jpg!
Blue Sofirn SP10b
I performed the following mods on this light:
- Replaced driver with 17mm Mountain Electronics driver with D4 firmware.
- Replaced stock microswitch with a different one
- Replaced stock aluminum star with a copper Noctigon (16mm star filed down to 14mm)
- Replaced stock emitter with XPL HI 4000K 5D
- Wire bypass performed on both head and tailcap springs (with copper disk added at the top of each spring to protect the wire bypassâ solder.
- Aluminum ring glued around top of external switch button. Converts the raised pushbutton into a flush pushbutton. Greatly minimizes chances of accidental pocket activation when lockout is not used.
- Replaced stock lens with UCL lens from Flashlightlens.com
Not a hard mod as Iâve done this before previously on a black SP10 and on a Thofire TK05. However, I quite like the look of the blue anodizing on this one.
How did you get the ring off? I could never get the ring off.
Which ring?
If you mean the SP10Bâs driver retaining ring I did it the usual way:
- Wrap head of the light in 3M indoor stairway grip tape. This is a very sticky and grippy rubber tape that provides great grip, yet peels off cleanly when done.
- Then I just used Snap-ring pliers inserted into the slots in the ring and turned and off it came.
If you mean the metal switch-boot retaining ring, I didnât remove it. I just glued a new ring on top of the old one with arctic alumina.
Bought one of the latest batch of BLF-348âs from Gearbest and found out they are putting 219Câs in them instead of the advertised 219B 45K so I put in a Samsung LH351D instead. I think the dome is a little too big but i got it together and it looks fine so, good enough.
Also flashed my D4 with Anduril thanks to some extra inspiration from user goshdogit - now to do some temp calibration cause this thing got WAY hotter than I expected so the temp must be way off.
I got my new Titanium Emisar D4 and itâs a beaut! The copper head section is superbly made and finished, the battery tube has a square checkering for knurling, just all in all a very well done little light! And the 219Câs make 3100 lumens at start on a VTC6, works for me! I really want it to have Anduril like all my others but I am loathe to disassemble this beauty. Itâs so deserving of candlelight though, and the ability to limit the ceiling on the ramp works magic to handle all the heat, so Iâll probably end up taking it apart anyway and getting it converted.
Thing of beauty though, for sure, well done Hank!
