I filed down the rim of the s2+ pill and polished the whole shelf to fit a 21mm ViRenCe mcpcb. 4500k E21A, 45° optic, LD-a4 driver.
I did the same for this old HDS but copper disk. 3500k E21A, 60° optic, LD-a4 driver and clicky switch.
Hi guys, need your help.
I got into possession of one like brand new JETBeam RRT-3 (review link) but LED (SST-50) craped out, I want to replace the led (not with SST-50 but something in 3V range like SST-40 or something more exciting) but first I need to disasemble it and here lies the problem, there is no obvious way how to do that, I need instructions of someone that already opened one. I don’t want to use brutal force and risk damaging the light.
I have experience with JETBeam RRT-2 and its not just matter of unscrewing the thing, that one was assembled with bolts (driver, magnetic ring and parts of the head that hold all this together) but I can’t find the bolts on RRT-3!
With this (magnetic ring) lights it’s hard to speculate if you don’t own the light.
Got a Jetbeam II MK with a faulty driver. Repairing it wasn’t possible due to my eyesight, but I always wanted to mod the C8 I got from Chibim, so I took its driver and implanted it into the Jetbeam:
Now it has mode memory! It’s the old UI, 2.8A.
How it’s done: Bezel can be unscrewed easily, LED board has two screws. Driver is glued, if you have nothing to lose, it comes off easily, too . The driver needs the brass contact ring from the original driver! Soldered the LED board, glued the C8 driver, all good. Lost moon as the lowest mode is 5% but doesn’t matter. I have other small lights as EDC, this is a backup.
Kewl… I thought Jetbeams were usually glued out the wazoo, else I would’ve tried to change the hideous green LEDs in ’em.
I might give it a shot…
Be careful with the bezel. No glue, but you’ll probably need pliers. It’s possible to get grip on the bezel without touching the nicely anodized aluminum. I did it with the nextool flagship pro pliers.
Yeah, if anything I’d try with a layer of rubber (making sure the pliers, etc., wouldn’t cut through it) and then try to work it loose. If no joy, then I’d leave it, puke-green and all.
Beautiful lights, I got a few Is and a II, and they’re top-notch except for the greenery.
I have a flip flop (sandal) nailed to a board for unscrewing hard to remove bezles. Press the bezle into the flip flop and rotate the body. Zero damage.
It’s been a while since a mod made me grin a little like the first time I used a FET driver but this one did. Sometimes it’s the little things…
Light is a Sofirn C01S
12mm FET driver from MTN with guppydrv Rev2 (1.6mm PCB thickness)
Stock SST-20 4000K and thin AL PCB
The wires that came with the driver are around 24AWG I would guess and did just barely fit once trimmed to size. I spent more time sanding the diameter of the driver to fit than I did any other part of the mod. It’s thicker than the stock driver but seems to still work fine. 1.0mm might work but I err’d on larger, i’d have to re-measure stock driver.
Used some better thermal paste and solder blobbed a Vapcell 10440. It still made connection even with the “flat” top but I didn’t want it to rub the wrap any just in case.
Turns on at over 425lm!
I suspect it can do better but i’ve never replaced the tail spring in a twisty before, any suggestions on how to get it out and fit another one? If I do that I may spend the time and try to make a kaidomain 10mm copper board fit but it would need modifying for LED wires and to be thinned out.
Current sense resistors… Umm, yes (should be the parallel R10’s)? Serious question? Also, I’m guessing that’s from a magnet ring switch light? Looks like Hall effect sensors around the outside.
And yeah, WTH is going on with that one side?!
Also… Why on earth did they need a 24MHz oscillator crystal?
I’m guessing heatsinking for some component. Made from whatever random recycled bits they had laying around. Probably the buck / boost controller iC.
Just a guess.
Yes, the driver is from jetbeam rrt-3 raptor single led (sst-50) version (img in post #8104).
I presume that small brass part is what on some models goas on end of the spring contacting battery, RRT-2 has the same thing but there it is actually useful, here, they just glued it on the board!!! Why? Maybe as a spare part, who knows! Cereal_killer might also be right, only one way to check
As per 24MHz crystal , I am puzzled also. My initial thoughts ware that maybe transition between modes is done by ramping up or down and for that they used oscillator but it jumps straight into modes, so no ramping…
I would guess that those are current-limiting resistors, not sense resistors. But I may be wrong
After the nice driver mod by contactcr and the Sofirn news, I though I should do something with the C01S. In the past, I put honeycomb optics in one regular and in the BLF C01S. Today I replaced the LED of the regular model by a SST-20 at 2700K. Beautiful color
Two firsts today; first triple build and first switch bypass! Haven’t properly played with it yet but so far so good.
- Eagle Eye X6 host
- Eagle Eye A6 body tube
- LD-B4 12A driver
- MosX MCPCB
- LH351D 4000K
- Switch bypass
Still a great mod and probably takes quite some time to really saturate with heat
The A6 tube fits the hand so much better than the stock tube, really fits the look of the X6 head… nice job! :+1:
I had to re-thread the pitch on the A6 tubes for the BLF and KRONOS X6’s I did a spell back…
I bored/thread a 21700 Sofirn C8F battery tube to another… Just not deep enough initially, was worried about crashing into the driver retainer ring…
Did you have to re-thread your A6 tube for your X6 head?
Very nice Kawi, love the colour combos
Nope, all stock. Threads are square cut and practically identical. The head end of the tube is 1mm longer so doesn’t screw all the way in though. Not a big deal and would be relatively easy to sand/grind down I guess.
Nice work, does me good to see the X6 gettin some love!
