Thanks! After more than a few years of learning from this forum and countless failed mods and destroyed drivers, my average on simple mods is on the up. I can't seem to give up on an old host.
One more old mod from a few weeks ago with another old, forgotten host:
- Jaxman X1 flood version
- MTN fet 20mm, old
- sliced and diced 3v XHP50.2 from sofirn store back when they still had sub-6000k in stock. Sliced with a washer and lubed razor, cut the sides around the LES, and sanded it very carefully with 1000 grit, 1500, 2500 and finally 5000, then cleaned it very well with alcohol and electronics cleaner. Sanding may not have been nevessary, but I wanted the top to be flat, and since this was my first slice attempt, it was uneven prior to sanding. I think it was around 5700k originally, now something around 5k, but just neutral enough for my liking since I don't really like anything that's blue or cold white. It makes the cold white xhp50.2 in the sofirn SD05 look cookie-monster blue by comparison on a white wall.
I got this old version of the X1 on ebay years ago in a "for parts" sale since the previous owner destroyed the driver in some mod attempt. Ever since, I've been practicing/destroying parts in it for years. It has a brass pill instead of an integrated shelf. In it's final version that now finally actually works, I soldered the driver in more cleanly than in this pic. I had pretty much destroyed the driver cavity through tons of stupid experiments. This is the final mod for it and I'm happy with the result.
Original failed "mod" with dedomed XML2 U4 1A I did a few years back before shelving this host and nearly throwing it away a couple of times:
![](https://i.imgur.com/KmTllkt.jpg)
![](https://i.imgur.com/y06cWvf.jpg)
![](https://i.imgur.com/VEurg5T.jpg)
![](https://i.imgur.com/XGXgywh.jpg)
I think the efest 26650 just blew the bond wires direct drive, because I've dedomed this led before with no problems on an 18650. Who knows, because I can't remember the mod details or what went wrong. You can tell from the over-use of ceramique 2 that I had no idea what I was doing when I modded it before, still don't. But learning.
Anyway, I removed all the old paste, torched away all crappy soldering, cleaned it up, and put a fresh mcpcb in there soldered down after polishing the pill a little bit. I also put thin tinned copper strip on the threads of the pill to increase conductivity and heat transfer. Screwing it in was a bit tougher, but not impossible and it's still removable. I got the copper strips from a reputable Ebay seller intended for soldering/spot welding battery packs, but I've used it for this and on an S2+ pill with success. I only use a weak keeppower 26650 with it now so I don't blow up the led, but it's got something like 9-10A at the tail on turbo. Not bad for something I almost threw away several times in frustration. Lots of flood, and at least 400m of throw, uniform tint with no green or shifting.
End results below with comparison to M26C (sst-90.2 delens), KD copy of convoy L2 with XHP35.2 and convoy 2.3a driver, and 2 cell genuine L2 with sliced/diced XHP70.2 and 4a buck driver.
Left: X1 with sliced XHP50.2, Right: L2 copy with XHP35.2
![](https://i.imgur.com/pkhKkWd.jpg?1)
From top to bottom: M26Cvn - SST-90.2 De-lens, X1 with sliced XHP50.2, KD L2 copy with XHP35.2, 2-cell L2 with sliced XHP70.2 (taller, so appears larger)
![](https://i.imgur.com/fjQWyy2.jpg?1)
26650 light comparison, the X1 is noticeably smaller and chunkier, I like this old host now instead of wanting to spike it on the ground and throw it away![](https://budgetlightforum.com/sites/all/libraries/tinymce/js/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
![](https://i.imgur.com/53BxWAi.jpg?1)
Thanks for everyone sharing their ideas for me to steal and knowledge to learn from!
