Convoy S11 with fc40 4000k and 25° tir lens. The lens is a bit shorter than the reflector, so I soldered a brass, round plate to the driver’s pin and additionally a spring. The battery fits perfectly now.
When you use around 7 m3 per year it’s kind of a necessity. And don’t forget, it’s not just the splitting, the trees don’t saw themselves into short pieces and magically appear next to the splitter. Some luxury is permitted
I know all too well the amount of effort it takes to go from standing trees to burning it for heat. For many many years I cut, hauled, split with a maul and stacked 3 cords (common US measure) or about 11 m3 every year. Now we use mostly stored sunshine (big LFP prismatic cells) and run a mini-split off that. Lots of sunny days even when it is cold. We have a token wood stove and might use a single m3 over winter. I find I still like to cut and prepare the smaller amount but don’t miss needing to do the larger volume.
Here are the lens. Of course you have to remove the white holder.
I also used a centering washer (probably this one) so that the lens does not rest directly against the diode.
Recently, everyone has dedome the 519, but I still like the sliced 351d.
Convoy S5 with a mix of 2700k, 3500k and 5000k, 10508 optics, biscotti 5A driver and custom aluminum spacer.
Last week I got my Kizer Feist with paper micarta (“Richlite”) scales, super pretty and they even changed the blade shape a bit more to my liking (less pointy) compared to the original Feist. Love everything about it except the clip, it is right-hand only which really does not work for me, and it is not as nice of a design as the rest of the knife.
So I removed the clip, but was leftover with the ugly attachment groove and holes.
To fill that up I looked for material that matches the scale material, and I came up with this bamboo/resin cup that we never used. The material and darkness of the colour matches quite well, just the tint of purple is a bit diffent. Good enough!
So I started with sawing a bit out of the cup and started sanding from there.
The material appeared to have multiple weak points, so several attempts ended in cracking the material once it got thin and nearly in shape. Finally I got a strong bit that held up to the end.
And here is what I ended with, lots of waste material, a broken cup, but also the tiny chip that fitted the cavity.
I glued it in with Araldite clear epoxy.
And after the glues was set, I shaved the excess glue with a scalpel and tried to level everything as well as I could with fine sand paper.
Pretty happy with the end result, much better than those unused holes.
Put a 219b SW35k into a Thrunite Archer Mini. Just created the greatest pocket light ever.
Not posting photos because the bezel is looking pretty destroyed. It was not an easy project, every time I went to screw down the bezel and TIR it kept spinning the PCB and ripping the wires off the driver. Also the reflector sits so low you have to be PERFECT with your solder, one nanometer too high of solder and your shorting the leads on the reflector.
I have had Convoy M21C for a while and I haven’t found any use for it.
I decided to modify it to use 3 XHP50.3 Hi’s in 4500K and 90cri. I hoped it would be bright and sustain that brightness well.
I ordered triple reflector from Kaidomain and modified it to fit M21C host. It also needed ~15mm tall spacer with wide enough head for 3 16mm mcpcb’s.
Next I modified GT-FC40 12V 2.5A boost driver to 6V and 6.2A. That way every emitter gets little over 2A.
I soldered every led to 16mm mcpcb and wired them in parallel. I placed them on spacer with thermal paste and postioned them carefully to fit the reflector. Reflector had M5 threaded hole at the botton and I used that to secure spacer, reflector and leds to one tight package that takes same amount of space as the original reflector + led and mcpcb.
Next I just placed everything inside the M21C. Bottom end of the spacer sits where the original mcpcb would have been. I applied thermal paste to there as well.
Here are some photos of the end product:
Sorry, I’m bad at taking photos during the building process. I’m always in such a flow, that I don’t remember to take them.
Quick follow up. Did the same steps again, but this time with Sn60Pb38Cu2 wire and the result was much better. Moving/sliding the emitter into the right position was much easier than with the lead free solder. I’ll probably skip trying to acquire paste and continue with this as it works fine.
