agree, that is why I do not dedome 519a in V11r
V11r reflector on left, showing the supersized base hole, on right is a V10r reflector (from a light that came originally with XP-G. these reflectors work perfectly w 219b)
beam comparison:
it Might be possible to use a dedome, IF the mcpcb is raised about 0.5mm. It may also be necessary to remove the stock centering ring (which means centering the LED by eye), and replace with kapton tape, or one of these nifty stickers
Lifting the LED has worked for me when using E21a and also 219b in V11r. I kept the stock centering ring on those mods. I have used 5x layered thermal tape, between the mcpcb and shelf. The tape also helped me to hold the mcpcb where I wanted it to be, to center the LED by eye.
Another way I gain height of the LED is the mcpb I use is 1.5mm, while stock is 1mm⌠but the centering ring creates its own spacing between the mcpcb and reflector base, hence lifting the LED does not necessarily move it closer to the reflector⌠it migh just raise the height of the stack (mcpcb + centering ring + reflector + lens), which is revealed by a slightly larger gap at the bezel.
the V11r assembly also uses a shim below the reflector, this could be removed to lower the reflector. (shown here on a V10r Ti+, that uses the same XML as the V11r)
disclaim, I have not tried removing that shim⌠proceed with cautionâŚ
here is a full modding sequence album for that V10r Ti+
Cut down my old SIM card (mini, 2FF) to micro (3FF), per what the blurbs said it took.
Then I find after I open my phone that it takes nano (4FF), so had to recut it down to that.
Forgot to clip the corner first, so had a symmetric rectangle of pretty much just the metal pads, and of course with 50/50 odds, I stick it in wrong at first. (âThatâs what she saidâŚâ)
Then, aha, this pin here should be âgroundâ (connected to the center pad), so flipped it, and it worked.
Oh, and then letâs not forget actually planing down the entire card because itâs physically thinner, too.
Btw, wtf does simple messaging need with location, camera, microphone, fân EVERYTHING before it works? I just want simple SMS ferchrissakes.
I get the feeling all these new incarnations of even the simplest stoooopitest things are gonna be that way.
Most default messaging apps now include features like video chat and location sharing. If you donât use those features, it will probably still work for basic messaging if you deny those permissions in the settings.
Thatâs what I wouldâve thought, but it was a no-go. Would go right to the âyou need to turn on these permissionsâ screen and other than backing out (only to try again), left no options.
I really want to get out of the Googooverse, butâŚ
Way back when (and Iâm sure you know this), neutral white meant LEDs that were warmer (like 5000K) than cool white.
I bought a cool white Sunwayman D40A back in 2014 to get the most lumens, and then bought the neutral white version soon afterwards. I sure liked the neutral one better! Weâve come a long way since then!
I like them a lot, beam wise seems similar to a LH351D, I like the color, very even, not a lot of tint one way or another.
Still waiting for my Oshpark boards to flash it and itâll be done. You guys werenât kidding about pulling those wires back up through the MCPCB, what a pain!
Tip for when you are trying to pull difficult wires through an MPCB or shelf:
Solder long thin wires to the tips of the driver wires. These extra wires might be 2 or 3â long.
Use these wires as guidewires. Since theyâre much longer and thinner you can easily thread them through a difficult MPCB or shelf. Then pull on them to pull the underlying driver wires through difficult openings and into position.
Once everything is threaded through, desolder and remove the guidewires.
Save the used guidewires for your next difficult install.
