What did you mod today?
I was thinking maybe I should participate in that contest, but I might still build something else. It’s past midnight before it’s dark enough for beamshots. Northern country problems. In summer there’s never dark and in winter there’s never light.
With these skills and ideias, I guess you should really participate :wink:
Oh, I know , not easy to take some bemashots at this time of the year :expressionless:
It is probably a beast, though, shinning at the ā€œdarkest hoursā€ of the day :wink:
fwiw
Not all types of Beamshots have to be taken outdoors at night.
I take indoor beamshots during the day.
Here are some examples of different kinds of Beamshots, only the first example requires being outdoors at night, the other four examples are all indoor photos taken during the day:
1. outdoors at night
2. wall shots showing full beam profile, these can be taken during the day in a dark room or shady corner.
3. flat shots, this is by a window during the day, that is why you can see the flashlights, not just the beams. I find the gray soldering mat background works really well:
4. Corner shots (folded printer paper ā€œwallā€), also daytime
5. Composites w duv info, from a daytime shot, and measurements taken during the day in a dark room
It’ll just be a white picture :smiley:
this is a beamshot taken indoors during the day:
(if you cannot see my photos on BLF? here is a direct link https://i.imgur.com/5MXB2ZR.jpg)
Haukkeli’s monster mod is probably more than 30 000lm, so I’m joking about the resulting picture being simply white if taken indoors.
Like Zeroair’s beamshots that are done with fixed exposure/aperture for comparison.
I guess the problem is more the ā€œnightā€ thing, since in the Nordic countries by this time of the year there is light almost ā€œdayā€ and ā€œnightā€, so there is no complete darkness :zipper_mouth_face:
But I’d say that a ā€œclose to darkā€ environment will allow and even better photo and will still portray how good it lights the ā€œnon-darknessā€ :wink:
Unicorn 4000K 519a 10° TIR
Opple data:
Original MCPCB is pretty small:
Beam comparison:
Sunny TIR pattern visible on the wall:
Copper S2+ with 15A Convoy driver and three Osram CSLNM1 and Astrolux S1 lighted switch
Nice one Luna :+1:
Hallo to modders here.Please-i try to open the head of Sofirn SC32.New model out now…But its glued…Any idea how to open a glued head?Thanks a lot!!
I use 3M Safety walk tape. This is very stick grey rubber grip tape that removes cleanly and completely when done.
  • Tear off a couple pieces and wrap one around the bezel and other around the head. This allows for much better grip.
  • Still not enough? … apply plastic-jawed pliers on top of the grip tape.
  • Don’t have plastic jawed pliers? Cut a piece of 0.032ā€ sheet aluminum and bend it into a U shape, then wrap it around your light above the grip tape. Apply regular pliers on top of the sheet aluminum.
  • Apply muscles to unscrew.
  • Once open use a metal pick to remove the threadlocker from the threads.
  • Do mod, reassemble, remove grip tape.
I’ve generally found that this technique is sufficient to break most threadlocker used in lights. The only brand I’ve tried this doesn’t work on is Fenix. They seem to squeeze a whole tube of red threadlocker into their threads.
For lights where mechanical pressure does’t work you may need a blowtorch or oven to loosen the threadlocker. Then I’m guessing silicone or leather gloves to insulate the hot metal as you unscrew. I’ve never tried this method so do not know the best technique when applying heat.
Heating helps even if it isn’t blazing hot when you unscrew. I think it breaks it down a little each time.
To heat the light, put it in the sun for an hour or two. or, dip flashlight bezel in hot boiled water for a minute…
then use leather wrap and vise grips
or use strap wrenches:
Also important to note to NOT use a plain vise or anything that would squish either head or body out-of-round, because then you’ll never get it off.
I would not advise to dip it into water! I’d say that it is more risky than heating it with sun heat or even a lighter.
If there is any leak into the driver, it may result in damage when turning the flashlight ON.
Heat and force (vise, leather wraps) = YES; Hot water = NOT so much.
Just my perspective of course :wink:
He only dips the bezel part. That’s my method also. First whole head of light to freezer to shrink. Then just quick dip of bezel to boiling water. Bezel expanses when rest of the head is still shrinken.
Ok, I was just being cautious with that, because for someone unexperienced, it may result in failure. :+1:
I also use the boiling water method but the parts are in a plastic bag when they are dipped in the water. I’m pretty sure jon_slider also uses this method.
I will try it today.But the usb port is there…Need to be carefull,…
