Thanks to the ever-so-awesome u/INeedMoreLumens for having a couple of spare 519a DD’s laying around, my little KC1 is back in business after the “I’ll try to dedome this 519a… that’s not a 519a” mishap.
I replaced the led in my imalent hr20 with something warmer - xpl hi neutral (5000k…??) to xpg 3300k (what i had on hand). The beam profile is a little throwy for my preference so i scratched up the reflector. I overdid it and took the coating right off around the edge of the reflector. Surprisingly the beam smoothed out a little but not much. Comparison shot , skilhunt h04 left > imalent hr20 right
Did you consider scratching up (frosting) the lens instead? Like with some sandpaper. I’ve done that with good results to either smooth out the beam or to make it more floody.
I didn’t think of that. I feel like the lens would be easier to find a replacement so i should have tried that first oh well. Thanks for the suggestion, I’ll give it a try
I tried to contact the member that’s sells dcfix a few years back and never got a response. I haven’t chased it up since. I could probably use opaque scotch tape to similar affect…?
As far as no stripes… i guess it’s because i used fine grit paper. I would need to go and check it if you’re interested to know?
S2+ FFL707A 4000k Mule with Convoy 6V 4A boost driver
metal switch to rubber switch with amber led.
spacer = copper discs soldered together. copper rings to center 16mm 7070 mpcb and hold it down. matched height with s2+ triple. I accidentally chip the edge trying to solder the rings onto the mcpcb but it doesn’t affect anything. I had to grind down the driver retaining ring with Tungsten Carbide rotary bit to fit the 6V driver.
s2+ mule family
2700k/5000k LH351D + AD17 FET driver
219B 4500K + Convoy 12grp linear 5A
FFL351A 1800K/5000K + Convoy 12grp linear 5A
FFL707A 4000K + Convoy 12grp boost 6V 4A
Convoy T3 Ti with YLX N3535B @ 1.4 Amp (4*7135 105c)
Problem was that I couldn’t find the original special board, so I had to modify an XP16 board. As this is thicker, the head cannot be closed completely, a small gap remains between bezel and head.
but looks interesting nonetheless:
With full Vapcell H10 I got 400 lm @ 11000 lx
Not bad. The beam is ok, the tint is really good, with no green even on low, but the brightness is not that impressive.
I’ve never tried it - but how easy is it to solder the copper discs together? What kind of heat do you need? And any kind of particular solder or will any off-the-shelf stuff work well enough?
