One more RGB build in the pipeline, this time for dear friend.
I did a refresh today on an old Aurora 18650 host. I think I originally built this back in 2011-ish.
It had an xpg and a 1amp ak47 3 mode driver. The springs were tired and partially collapsed. It’s lived a fairly hard life in the center console of my car for most of it’s life.
Everything is an odd standard. 14.6mm mcpcb. 14.2mm switch board that lives in a threaded cartridge. Aluminum screw in pill that has a tapered brass pressfit ring for a 17mm driver.
I started at the tailcap. Stripped the switch down to the bare board. Used an 8mm diameter spring, then bypassed it. Installed a new omten 1288 switch.
Soldered a Qlite 4.5amp driver with guppy on it from MTN.
Reflowed an XHP50 to the odd 14mm aluminum mcpcb.
This thing is reborn. It slaps now. Even with the smooth reflector, it’s not bad.
To do list: find a copper 14mm mcpcb for a 5050. Seek out an OP reflector.
I think I can modify one of the “special” convoy mcpcbs to fit this host. It measures 14.5mm without the nubs. I’m hoping if I shave the nubs off, I shouldn’t have any issues removing an addional .3mm all the way around.
That 14.5mm one should work fine. You could even shave down a 16mm board. Any time you trim a board check that there’s not continuity between the core and the +/- pads. Cutting/sanding the edge can bend down the conductive layer into contact with the core. It’s difficult to see by eye so check continuity.
I have a few different 16mm mcpcbs on hand. I took some caliper measurements and feel a it would be cutting it a little close.
Maybe it’s just my boards.
I built my first driver last night. MTN17DD single fet.
I used some of the parts I ordered to build some Texas Avenger Fet+1+x boards, but am still waiting for the boards from Osh.
So I used what I had on hand for those builds on the MTN FET pcb.
I’m gonna flash it tonight and hook it up to the power supply.
Keep your fingers crossed that it doesn’t release the magic blue smoke.
It was nice using my new microscope to do the build.
Very nice mod! ![]()
Do the NBD110 work with the smooth reflector? What driver did you use?
Used an OP reflector as I find these are much better for dealing with artifacts in multi emitter setups.
Emitter swap on Zebralight SC5w and FW1AA Ti.
Zebra got FFL505 3700k rosy and FW got SFT-25 5000k 90CRI from KD
How did You manage to unscrew bezel of Zebra without any damage?
Years and years of practice and i was lucky this time. Usually on all old Zebras glass lens gets destroyed in the process.
How is the beam profile on the F1AA with the 25R installed?
A while ago I replaced both emitters in Wurkkos HD16 with LHP531 4000K. And, as I feared, killed the idea of this flashlight.
Today I’ve made the throwy channel throwy again.
Much, much better than 519. Small and shallow reflector just begs for DD emitters.
I modified my RMM modified Supfire M6 that I bought back in 2014 from Mountain Electronics. It came with 5000K XM-L2 LEDs and drew about 20 amps in turbo. Here’s a BLF review in case you are interested: SupFire M6 by Mountain Electronics, RMM’s #1
It’s been a work horse for many years, but no longer used. So I decided to replace the LEDs with some LHP531 5000K LEDs. I also replaced the reflector to have some more useful spill and also needed to replace the lens with a thicker one. Reflector, lens, and gaskets came from Kaidomain.
When I put it all together, one of the LEDs automatically turned on which was due to a short. I saw where the reflector was touching a MCPCB solder joint so I re-soldered all of them much shorter and that resolved the issue.
A very nice improvement in tint (no more green) and beam, and more lumens!
Google Reverse image search yield this Czinelight CZ-5054RGBWW
These look like a nice compromise
Another variation has rgb+cw+ww.
Are those glued to the heat sink? Or does the reflector keep the mcpcb’s in place? Nice solder connections, I have to work on getting them cleaner.
The reflector is screwed into place through a hole in the shelf. You can see the screw in the picture with the old XM-L2 LEDs. The screw is tightened from the driver side and really secures the MCPCBs onto the shelf.
Here are some pics on the driver side (and the screw) and the old reflector:
