Where are you located?
Perhaps there is a member nearby who has a quality power supply or even just a known good meter.
Failing that, perhaps someone can send you a battery that has a known V for you to measure.
All the Best,
Jeff
And here is an article about how to make an inexpensive low V reference source.
The trick with the parallel resistors to increase accuracy is nifty.
All the Best,
Jeff
To maintain certification, they usually need to be sent out to be calibrated annually. I have a friend who works as an aircraft mechanic and use his DMM’s or PSU’s to calibrate my own. Sometimes they need no calibration. Other times they do, regardless of how cheap or expensive the device may be. This works well for me, given the general level of precision I need. If I needed greater precision, Id send it out for annual calibration.
