Kershaw Believer 2070!
I got an email from eBay about the Kershaw Believer 2070 that I ordered:
"The seller canceled this order due to the following reason: I'm out of stock or the item is damaged.
They sent a refund to your original payment method."
I think they're full of it, but there's nothing I can do about it.
Frustrating.
They probably got busted for selling fakes.
In the market for a pocketable folding Cleaver. Seems to be quite a fashionable design style at the moment.
Ordered the Gerber Flatiron through Drop.com. The new 2020 release with D2 blade steel and Micarta handle scale.
I'm sure could find this edition in the UK eventually, but the Drop deal looked good and had previous orders without issue.
A little smaller is the new Gerber Asada - they changed the blade to Cleaver style for this year's release.
Just sold-through on Drop, so will have to wait for another drop, alse availablity elsewhere.
Of course, being the obsessive type, here are the Cleaver styles I was selecting from (and will probably end up with at some time)!!
Any advice, suggestions or feedback for next blade would be appreciated:
I knew it!
The eBay seller is now trying to sell the same item for more money.
The item isn't out of stock or damaged like they claimed.
I tried to report the listing to eBay, but none of the options fit this dishonesty, and I couldn't write eBay a message stating what this seller is up to.
eBay sellers like this seller make me sick.
I suppose you could ‘buy’ it again, and then not pay for it. Tit for tat?
Nah, just buy it again, dab it with coke or maple-syrup, anything brown, then let it dry, snap pix, and pan it in reviews saying you got a rusted POS and want your money back.
Got a CJRB Barranca on the way. Love the blade shape, but the flipper tab design not so much. Can’t wait to get my hands on it.
This will be my first CJRB knife. CJRB is the budget line from Artisan Cutlery.
On another note. I received the Real Steel H6 Special Edition ll today. Great blade shape and sharpness. Great G-10 scales are nicely textured and grippy. Great ergonomics. Love the jimped thumb ramp. Thumb studs are a good size and well placed.
Don’t like the action all that much. There are washers instead of bearings, and it is very noticeable to me. There are two different sized torx screws. One size is a tiny T-4 and the other is T-5. I prefer one size, like a T-6 all around. The pivot screw is semi-stripped out. I will contact the seller and see whats going on with that. The box indicates that it is a 2016 production model, so maybe quality control wasn’t so great back then, and they overlooked the roughed up pivot screw…?
Not a knife, but I ordered the new RUIXIN-008 guided sharpening system ($35 on AE). I first got into guided sharpening with a $18 EPA clone, horrible build quality out of the box with nearly useless stones, but I managed to greatly improve it using a file and dremel. Even with the crap stones I was able to give my cheap kitchen knives a better looking edge than I ever could by using a wetstone.
I also ordered a decent set of Boride stones from gritomatic and a cheap set of starter diamond matrix stone to work with S90V and M390 steels.
Sharpening is getting more addictive than knives…
Whet and oil stones were all the rage. forever. Till some decent adhesived Diamond chip ones appeared.
Nowadays. Most I know use the diamond plates or/and steels.
But it’s a good idea to buy a long and short blade, cheap knives.
To practice on the angles and strokes With pressures to suit.
Before getting into the Diamond seriously.
They can pull a LOT off your blades if you a little uncertain.
I keep a 6 in Ruby stone though. Just for polishing blades.
They give a much smoother face to blades.
Check on sharpening forums for decent plates.Steels.
With reviews. on how to.
There are a lot of cheap rubbish ones out there.
DMT are good.
I purchased one of these before Christmas. Amazon.com
The stones it comes with wear extremely fast and are pretty low quality with plastic backings. They can however sharpen a knife very sharp.
The real investment in a knife sharpening system is the stones. The stones make all the difference in the world and can be quite expensive.
I have more in stones than I do in the edge pro clone by far.
A few places I purhased stones from.
All 6" Mounted Sharpening Stones, Strops and Blanks - Gritomatic
Edge Pro
Mold Shop Tools - ABRASIVE MOLD & DIE POLISHING STONES
You can purchase a aluminum 1” x 3’ flat at lowes and cut into 6” pieces which will yield you 5 backings to glue the stones to, you lose a little material with each cut.
https://www.lowes.com/pd/Steelworks-3-ft-x-1-in-Aluminum-Solid/3053631
I used 3M 77 spray adhesive from lowes also. Cut your pieces and grind or cut a bevel to match the existing bevel and glue the stones on. You have a lot more choices by making your own.
Cold Steel Click n Cut, TAD Mummert eCutter( not too impressed with this- cuts into your finger in use.), Tokisu Naga ( really nice cleaver type Japanese knife ) All recent, Spyderco Meercat HAP 40 a few months ago and all from Heinnie Haynes.
From Edgar Brothers,Spyderco Manbug HAP40, Spyderco McBee CTS XHP.
Also three knife nick / knife openers by Rough Rider and Case.
My favourite this year though is a DPx HIT cutter a weird concept which just about works.
Used most is an Olfa 9mm 30 degree craft cutter with snap off blades. Ideal as a box cutter and envelope opener.
On its way from Amazon US is a Blackhawk Hawkhook + 3 DMT mini whetstone diamond sharpeners, course, fine and extra fine in a set- an absolute bargain for quality sharpener, cost more than double in the UK.
Good job I don’t spend much on Flashlights.
Twosun TS66 with white and blue G-10 scales, and a 14C28N blade. Had the winning bid at $32 on eBay.
I am attaching a link to the exact knife sold on AE, just to show you all what it looks like. Heckuva chunk of 14C28N Sanvik steel, ceramic bearings, and beautiful G-10 scales for only $32
Land / SRM 811 (black stone washed)
coming in through AliExpress.
Now only the Land 9x is missing
For sharpening I changed over to Diamond plates decades ago
Just use a small hand stone. (Ruby) for polishing blades.
I find the DMT plates best value for money and easy use
6in by 2 in seem to be the easiest for long stroking 6in plus blades.
Shorter ok for folders but these the better.
Mounted on a cheap sliding rod on stable base unit.
There are several avail on net.
Just practice on a cheap blade first for angles
and PRESSURE on the blade.
The cut the steel away rather rapidly if you not careful,
believe me.
Be careful with the cheap diamond plates,
they flex a lot and need mounting on a more rigid backing
to give decent sharpening angles.
I used to carry a small round axe stone for touching up in bush.
Hunting and skinning.
Oil soaked. But last 30+ yrs It’s been a small diamond pencil steel
for a MUCH better job.
I ordered two knives recently...
and
Kershaw Passage 1361!
Kershaw Payout 2075!
Kershaw Cannonball 2061!
I’m a knife “muggle” but I apparently might be able to go straight to the head of the class with a Sanrenmu 9201, which I bought from the Sanrenmu store on AliExpress. But it’s on the very slow boat from China (PostNL).
