What Legoes with What?
Just found out that the switch of a Convoy S2+ fits into the Mateminco FW2 /Astrolux WP4.
Indeed! I swapped a forward clicky switch into my FW2 using a Convoy 16mm PCB & spring. I swapped the weird salmon boot for a black one from an SC31T.
Sofirn LT1 Mini & Sofirn C8L’s tailcaps can be swapped.
LT1 Mini’s tailcap on C8L requires the tailcap to be loosened/tightened to turn the light on/off. I suppose it does allow tailstanding though, which is an improvement.
The C8L tailcap on LT1 Mini prevents tailstanding because the button protrudes, and Anduril does not turn on automatically when connected to power so the switch just serves as a mechanical lockout.
Does anything Lego with an IF25A? Say if I wanted a magnetic tail on it, what would work?
It will probably be easier to glue a magnet in the tail!
This is a very minor Lego but the tailcap from Skilhunt M150 threads directly onto the Sofirn SP10 Pro. It’s a much better design and also magnetic.
Hi guys, I messaged Simon to check if the S2+ 18350 tubes work with the S6 and they do! He said to use the new square or rectangular cut threads. The previous trapezoidal threaded tubes don’t work but the ‘newer’ ones do.
Here is the S6 with shorty tube next to a regular-sized S2+
I can confirm the fit is correct and it works perfectly! I’m very pleased.
I need info on that cool pocket clip please?
Looks like a thyrm switchback or similar
It is a clone of a Thyrm Switchback 2.0. The quality is not quite as good as a real one but I have both and the clone is still plenty good, especially for the price of less than $2.50.
This seems like an appropriate thread to share this information.
The Wurkkos TS21 Pocket Clip fits a Convoy M21B PERFECTLY!
Also, the pocket clip from an Olight Perun 2 (which I believe is identiacal to the M2R Pro Clip) also fits the M21B 99% perfectly, as well as fitting the TS21 if you wanted a slightly longer clip with slightly deeper carry.
Below is a photo of M21B with TS21 Clip.
You can see the part of the clip that grabs the flashlight is exactly wide enough to fit perfectly.
Below now is a photo with the Perun 2/M2R Pro clip.
You can see here the part of the clip around the flashlight is slightly thinner than the groove it sits.
Its not bad at all, but the TS21 is just perfect.
Although, this one is deeper carry which is nice.
You’ll also notice that the other end of both clips land in the same spot on the battery tube.
Here is the TS21 with short tube using the Perun 2/M2R Pro clip.
Not much to be gained but slightly deeper carry.
For comparison, heres the TS21 with short tube using its own clip.
QUESTION
Does anyone know if the head of the Foursevens Mini Turbo MKII fits and works with the battery tube of the Foursevens Quarks (16340/ 16650)?!
The best images I can get from these models (well, their recent versions) are here, but I can’t really say if they fit and work :zipper_mouth_face:
Can wurkkos ts11 use sofirn sc31pro 18650 body?
The Convoy S16 tube with tail switch fits Pionemam K36 and Convoy M21E, so you can avoid Pioneman boring hold for off, and make both tacticool.
I believe the Pioneman k35 will also fits both.
Not sure if this has been mentioned before but the Wurkkos 20350 tube fits the Convoy S21A:
I did wire wheel the threads that go into the head to make electrical contact.
Oh good!
I was going to ask here if the 21mm sized Convoy bodies would fit the Wurkos lights… Gets some color options!
I’m running Convoy S2 18350 tubes in my Sofirn and Wurkkos 18mm batt lights. Just need to sand one end of the tube lightly; one end contact surface on the convoy tubes are anodized; prevents contact to head/tail cap in the others.
Your M21B tailcap looks very different to mine. Is that a custom job? Or an old version of M21b?
It looks to me like a standard tailcap that has been modified on a lathe to remove the button shrouding.
