I think the hotspot size will also depend on the host too.
I have a direct drive XP-G2 C8. I keep thinking of de-doming it, to see how much more throw I can get from it. But tbh, the beam is already rather narrow as is. De-domed I think it would be a trick light for sure, but actually pretty useless. Which is why I’ve resisted de-doming it for so long.
I do not have any photos. I do not have the proper camera. There is nothing left to prove,other than look at selfbuilts reviews and JMP320 measurements of Vinh lights.
To give you an idea because SB and Justin did not measure the TX25C2vn, the S200C2 has a bigger head and is about 1.5” longer and it is a single cell light.
They both have credibility.SB got 137Kcd w/ the S200C2vn XPG2 and Justin[JMP320] got:
Eagletac s200c2vn XML2 PDT Direct Drive single mode
Samsung 20r
1266@ turn on
1227@ 30 sec
Throw - 153,000 Lux
From my reading here, it seems as though the OP, carbine15, wants something that will fit comfortably inside a pants pocket. Although carbine15 has not flatly ruled out 26650 options, he has rejected the few that were listed. I think he also has rejected 18650 flashlights that have a wide head. Otherwise, flashlights such as the BLF Kronos X6, the Nitecore MH20GT and the Manker U11 would be prime candidates. The Convoy C8, M1, and M2 (potentially, with mods) are seemingly too big, as are the Eagletac S200C2 and other Eagletac models.
The only small flashlight recommended so far that clearly would out-throw the Nitecore P12GT is the BLF Kronos X5. It would only do that for about 15 minutes, however. After that, it would be time to recharge its 14500 battery!
Let's narrow down the question. Sticking strictly to 18650 tube lights, are there any stock flashlights that out-throw the P12GT? The head should be no wider than the body.
Ok, regardless of where you were, I don’t believe you can tell with just your eyes that the light was .25 lux and not .20 lux. Our eyes just do not have that level of precision in judging light levels. Your light was tested with a lux meter at 65kcd at 7.5m. Please just get a lux meter if you want to make more measurements. It is not helpful to make measurements of light levels with your eyes; it is simply not reliable.
Beam comparison… my stock 123mm Eagtac P25 XP-L HI w/ 1” head is brighter and out throws my stock 140mm 1” head Nitecore P12GT. It seems that Nitcore overestimated it’s throw while Eagtac has most likely underestimated theirs.
I think the P12GT and P25 have pretty close to maximized the throw for this size of light (stock). Ok, the P25 might be a little brighter, but probably only by 10-15%, not enough, IMO, to buy a whole new light that is similar in most ways. To get significantly more throw, you would need a larger reflector or a modded light with a higher luminance emitter (like dedomed XPG2).
I agree with you, but since we seem to be splitting hairs, and size is paramount… the Eactac is fits in my pocket much much better. Measured hotspot from eleven feet… P12GT - 12”, P25 - 9”
Right,and if 10 people test a light your going to get 10 different measurements.
It is very unlikely that YOU would have an idea that Vinhs measurements are a little low because of his lack of space.I never have seen you on his threads on CPF.I do not believe you own any of his lights.
I can tell you that it MOST certainly seems that my light surpassed 65Kcd.
From 65Kcd to 80Kcd is only a difference of 60 yards of throw!
Here is where I am a fool! Why do I waste time trying to prove something that MOST people on here are going to dispute because this is BLF and I am talking about a modder on CPF!!!
P.S I noticed you did not comment about anything on post # 28! Did you learn anything about measuring lux and the differences that measuring distance creates??
Man, you need to stop ‘Stevedog’; and stop now!!! Pleeeeeaaaasssssseeeee……….
You are making it almost impossible for me to not get the EagleTac………… :person_facepalming: … :money_mouth_face: :money_mouth_face:
In fact…….
Is THIS the one? It says P25 LC2 not just P25???
Of course it would have the XP-L HI emitter. Which tint, cool?
Yes, thats the one… in cool white. A couple things to consider b4 purchase;
No bells or whistles on this model,
Simple UI, no battery voltage indicator, and no overdischarge protection. It’s regulated, I ran my 3500 mah 10 amp protected Panasonic down to 3.3v without any noticeable brightness reduction.
It was never a measurement[of lux], just an educated observation! The only and an important measurement was the DISTANCE by google Earth,which I deem accurate!
If it is not exactly 80Kcd I know it is close and I am very happy with my light!
Lets let the OP and others get on with this thread! :sunglasses:
I had this the past year and played with it for like a day: used one of my best S4 2B emitters( it was 4.9 amps capable, clean electricaly dedomed)
One will never ever get 80k cds from this light with even 15%–20 better emitter than the one mentioned above( whitch i cound nearly impossible), i could barely reach 62 with VTC5A at 4.21V
Maybe if it was touched by God then maybe….othervise i count this highly unlikely
The T01 and X5 are 14500 lights, share the same reflector (mas o menos) and are exceptional for their size. The MH20GT is also an exceptional light and not much larger than the X5 although it takes an 18650 and can use a high capacity cell for long run times.
If you were wanting more flood than throw, the MecArmy PT16, PT14, PT10 would be excellent examples.
lol! Maybe GOD touched mine because if it was not 80Kcd, it was very very close. If you read the prior posts about different ways/distances of measuring you will see that Vinh measures @ 7.5 meters. He is ALWAYS lower than selfbuilt[10m] and JMP320[9m].
Vinh measured mine @ 65Kcd.
Keep in mind that it is ONLY an additional 65 yards of throw from 65Kcd to 80Kcd…
Lets debate this for another 10 posts!! :person_facepalming:
I have the TX25C2 with a XP-L HI and a FET +1 driver and it blows everything else the same size away easily. I’ll try to post a pic later tonight against a stock Manker T01 and Manker U11 modified with a XP-L HI which are also a good small throwers for comparison.
Regarding my TX25C2vn. I do not believe I mentioned this. Here is the full name! TX25C2vn V3[VERSION 3] XPG2- DIRECT DRIVE/SINGLE MODE.
Direct Drive and single mode. No switch. Battery directly to LED. The least amount of resistance! Activate by twisting tail cap!
I know this. Vinh told me he could see the difference in beam intensity on the whitewall b/w mine and the standard mod. He said it was noticeable and probably 5Kcd to 10Kcd more beam intensity.
He did not have measuring equipment then. JMPAUL320 Did the measuring. Vinh did measure mine last year when I sent another light to get modded and he measured my TX25C2vn.
I believe him when he said he got the most possible out of my light by making it DD/SINGLE MODE.
We will never know,but if mine was tested against the standard mod and other mods that were NOT DD/SINGLE MODE, I am confident mine would have the most CD/THROW.
