What Reflectors for XR-E
Hi Guys
My first post so please be gentle with me :slight_smile:
I have just bought a headlight off EBay with the intention of using it on my pushbike (I’m showing my age by calling it a pushbike) and after turning it on I have found the beam to be far too tightly focused and would like to replace the reflector with something a little less focussed.
I have also noticed that some reflectors are listed as fitting other LED models eg this one from Fasttech http://www.fasttech.com/products/1617/10001275/1220101-aluminum-alloy-orange-peel-reflector-for-cree-xm-l
My question is what other reflectors will fit an XR-E?
Many Thanks for your time.
Markendo
What light did you buy? Did you take it apart and measure the reflector? How do you know this one will fit?
Firstly, welcome to blf markendo :slight_smile:
If the tight beam (throwy) not to your liking, I would suggest a wide beam (floody) emitter swap while keeping the reflector.
So, are you able to do some basic soldering ?
If yes, floody beam of Cree XM-L or XM-L2 might do the trick, measure diameter of the original and swap it in, good luck :slight_smile:
Hi Toaster, I bought this one http://www.ebay.co.uk/itm/310692447191?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1439.l2649
Yes, I took it apart, its 35x28, I only gave that link as an example of reflectors being able to fit more than one emitter, my thinking was that if this reflector will fit more than one emitter then other reflectors will fit more than one emitter.
Thanks
Markendo
Thanks for the welcome iron potato,
Good call on changing the emitter, obvious now that you say it :bigsmile: . I will have a look at the specs of both emitters. Back in a minute.
Edited to add
XR-E is 6.8mm accross including the silver ring and the XM-L is 5mm accross, so it will atleast fit into the hole.
Will this work?
Thanks
Markendo
XM-L/2 will give you larger hotspot, but not much, and some additional lumens. If that doesn’t do, you might also try wide lens instead of front cover glass.
Here's a 35mmx28mm reflector:
https://www.fasttech.com/products/1617/10001275/1209700
Plastic, but very cheap at 99 cents each. It's a smooth reflector which will be throwier, but with the application of an Old-Lumens stipple job...
https://budgetlightforum.com/t/-/11709
... would have a smoother/floodier beam. Another option would be to use a frosted lens which would eliminate the hotspot and make the light much floodier (possibly too floody for your application?). Try using some matte Scotch Magic Tape on your existing reflector lens to see if you like the effect. That can be easily removed to restore your light to original condition if you don't like it...
keltex78, That reflector looks identical to the one that is already in the light. I like the link to the stipple video might try that at some stage.
I think I will buy a few/lots of reflectors and a few TIR type reflectors from Fasttech and experiment with them. I might even buy a few drivers and LED’s. Some of the lens’s will require mods to the light but most of my other things are modded to one degree or an other :slight_smile: so that should not be a problem.
I bought the light with the intention of messing about with it so if I break it (it was only £8) then nothing lost as long as I learn from it and find out what works for me.
Thanks for the input.
Markendo
My opinion is: swap the xre with an xml first and then have a look if is is floody enough already, should make a huge difference and gives more light too :-) . If you buy one of these insulation gaskets as well, it makes the XM-L fit nicely in a XR-E reflector.
