I was using this light earlier to do some automotive work. And I accidently got some carb cleaner on the stock, plastic lens. The result? A translucent/opaque surface where the solvent dissolved the plastic lens. So I need to get a new lens, and would like to get a glass one so that I don’t have to worry about contact with solvents. However, I don’t have a way of accurately measuring its size. With a ruler, I’m getting around 41-42mm. Does anyone have a more exact measurement (with a mike or calipers) that I can use to find one at flashlightlens.com?
If your talking about The armorMax 3C a 51mm is standard and 52mm will fit no problem.
After a quick look one of these may be ground down slightly to fit if no one else can com up with something better.
Not the Armormax or the Super Thrower, but the standard 3C that was being sold at around Black Friday of last year. That one has a much smaller reflector than either of the other two.
Speaking of the Armormax, are you sure the lens is 51mm on it? 51mm is the size of Mag reflector. And the Armoxmax reflector is MUCH bigger than a Mag reflector.
Sorry StorminMatt. When you said 41mm to 42mm I thought that you were referring to the smaller light.
The first picture is what I was referring to above and the second is the lens from the larger Defiant 3C. A slightly bigger lens will fit in either if you can find one. Cheers.
Wow, there sure are ALOT of Defiant lights! But this isn’t the one. It looks like this is the 3C Armormax XP-G light. Mine is the 3C XM-L light (NOT called Armormax), like this one. As you can see, the head is considerably smaller in this light.
I cant help you with the lens on that light. Your right though. Plenty out there to confuse the issue.
There is one at Flashlightlens which is 41.8mm x 1.9mm thick and if this link works should take you there.
