I just got a convoy s2+ based on the good reviews here. Love it. Very bright and good build quality. Now im looking to add two more lights to the collection. I would like a good thrower and then something 1500+ lumens while staying in the 40-50 range. Just want ones that are reliable and well rated here. Thanks
Convoy L2 with XP-L HI, thrower and under $50.
For a high output light I recommend the JM35 XHP-50, its about 1800-2000 lumens.
Convoy C8 is a decent thrower.
Or this if you want a zoomie…
I just received the Shadow JM 35 and as above cheap price and definately throws the light. The side switch does rattle somewhat…but overall very satisfied. It’s an interesting Budget Light. I used a 4800mah 26650.
Thanks. What are the lumens on the m8 and L2? Are both considered throwers?
The C8 is a much smaller light with similar drive current. ~900-1000lm, ~20kcd
The L2 is a much larger light with a stock no dome emitter. ~1000lm, ~100kcd
L2 is a much better thrower.
i like my shadow JM35 as well, compact and lots of light! mine have a mt-g2 led.
Okay… here you go:
Supfire M6 Triple XM-L2 - Will get you the 1500+ lumens you want:
http://www.mtnelectronics.com/index.php?route=product/product&path=80&product_id=250
For the thrower:
The Supfire L3 is a nice light, and is a good option to mod out if you want to push it harder:
http://www.mtnelectronics.com/index.php?route=product/product&path=80&product_id=448
Of course, the C8 is a nice option with a fair bit of throw: (out of stock at the moment)
http://www.mtnelectronics.com/index.php?route=product/product&path=80&product_id=427
