Which ones?
Recent projects are BLF A6, BLF Q8, BLF GT… There has been others i’m less familiar with X5/X6… 348…
Use the forum search box with these terms, or Gogelo them.
OK OK. I got it What about Taking the Astrolux MF01 and double the cells and triple the output, 36000 lums with a slightly deeper reflector for even better throw and 10 tons of flood Or turn the BLF GT into the BLF ZR1 GT RS with 40 emitters and a copper head for cooling Lets beat the X80 and DX80!!!
In 2017 we’ve seen some good 18350 and 26650 batteries. I’d like to see some 32650 this year, as well as some good lights.
Also a quad-die led based on Samsung LH351D dies. In XHP70 package.
Yes. The two (longer) outer pogo pins fit in two somewhat bigger drill holes in order to keep the 6 inner connecting pins in place.
But you still have to press it down for the programming which only needs a couple of seconds. It’s not designed for debugging.
budget brands(astrolux, convoy, haikelite) have less minor problem, QC is better
famous brand has more budget friendly lights, or some unique lights, and more option about led
lipo battery becomes popular(it give higher current, so manufacture can do some epic light)
AND A CRAZY LIGHT, add as many emitter as you can, like 10 XHP70.2 AT 5000 LUMEN EACH ONE
I would like to see easily programmable lights, whether it be USB, or bluetooth. Something you can connect to a cell phone and program mode groups, ramping, thermal regulation, see temps and other specs such as voltage and amps at the emitter(s).
I would also like to see my UT02 and M6 have a firmware like the GT in it
