Miboxer C8 is so far my “go-to” charger, especially when charging different battery types/sizes.
Xtar VC8 (or VC8 Plus, for the version that has external AC power, and accommodates up to 8x 1Amp charging), the charger is divided into 2 sets for control.
So basically, the VC8 is like having 2 4-bay chargers each with its own set of controls.
However, each set of 4-bay can only do the same thing (charging, or discharging, or capacity testing, or storage), plus they can only be set to the same charging current. If I’m charging different size battery, I prefer to set charge current differently (eg. a 21700 battery and a 14500 battery needs a different charging current, or it will be too slow for one, but too fast for the other battery type, if set to same charging current).
The Miboxer C8 for me, although it does charging only (no capacity test or discharging function), the charging current can adjust automatically if one battery is almost full.
What I mean is:
1) On the VC8 / VC8 Plus, this charger can charge at 1x 3A, 2x 2A, or (3x or) 4x 1A.
as long as I have 4 batteries on the slots, then the maximum charge current will only be up to 1Amp (assuming using the external AC power, or using a QC2.0 USB charger).
so even if 2 (out of 4) batteries have finished charging, the 2 batteries not yet finished charging, will charge at 1A max.
2) Now on the Miboxer C8, the max charging current is 1.5A (it can accommodate 8x 0.8A, 6x 1A, 4x (or less) 1.5A)
So when we have 4 or less batteries, the max charging current is 1.5A. If charging all 8 slots, then the max charging current for each will be limited to 0.8A (at least that's what's on the display).
However, as we finish charging some of the batteries (or if some batteries are almost full, and their charging current decreases), then the other slots that are still far from full, can increase to higher charging current (up to 1.5A), assuming we did not manually set to a lower charging current.
So assuming I'm charging 8x 21700 batteries, but 2 batteries are already fully charged, then the other 6 batteries will increase charging to 1Amp. Let's say 4 batteries out of 8 are nearly full charged, then the other 4 batteries will start to increase charging current to 1.5Amp max.
I like this functionality (automatically balancing the current load, when a slot uses less charging current).
Unllike the Lii-S8 or VC8, where the slot will be "fixed" to a certain charging current, due to number of slots occupied/inserted in the charger.
