I’m going to convert a few lights to dual switch, amongst others the ZY-T08. I have the actual switches and have made my own E-switch PCB, but I need to find where I can buy the E-switch button cover and casing (or what ever they are called). Old-Lumens did this here SS ZY-T08 5-up Mod - Finished, but by reading his description he appears to have used parts he had from other lights.
Here I have shamelessly stolen Old-lumens photos from his thread. Where can I buy switch housing like or similar to these?
If it’s not OK to borrow photos like this, let me know I’ll edit them out.
For lights I modded into side E-switch lights, I made my own cases out of sheet aluminum cut and bent into shape. In my first one I screwed it on with 4 small screws. The button cover was a standard tailcap button that I’d cut and trimmed into a flat cover.
For my more recent ones I glued the cover on with epoxy and used a metal piston with #6 finishing washer.
Here’s my first attempt (modded Aleto N8):
Here it is again with some grey duracoat on. I also glued a strip of aluminum around the inside edge of the button hole. This helps prevent accidental activation by making the button slightly recessed. Also makes it stand out a bit.
Here’s my second one (modded Convoy S2+ mini). The switch cover is glued on with arctic alumina. If I need to service the switch, I can remove it with an exacto knife. The button is again a standard rubber tailcap switchboot with the sides removed and the top cut down with an exacto knife.
Here’s my latest one (Aleto N8). Cover is glued on instead of screwed. Button has a piston from a DQG Tiny III surrounded by a modified #6 finishing washer.
I recently recoated my Aleto N8 in tactical black duracoat. Here’s what it looks like now:
I guess if I get tired of the Duracoat I could remove it and go back to the polished bare metal look.
I still have the older Aleto N8 body with the screwed in cover (now also coated in tactical black) a couple extra heads and a driver. One of these days I’ll get around to modifying another pill and then I’ll have two N8s.
I dont know it, i searched more than one Time…
These switches like in post #3 are nice, but huge they often are 40mm long that is why it would be so neat to use a small SMD switch on a pcb.
Maybe a small momentary switch could be dremeled so that it can be used.
The only things I have found out is the different names:
Electronic switch, momentary switch and non latching switch…
And that the prices are from 1-100$ for a single switch…
One smart guy here has made a very elegant piston which is a piece of round metal which goes inside the head and pushes a SMD momentary button. I believe it was also an s2…
An electronic switch is simply a momentary push button coupled with a circuit. The circuit can be either part of the driver or on a separate board.
Momentary switches are quite cheap. For my N8 mods I bought a bag of 100 tiny momentary push buttons on EBay for $4. So each switch cost about 4 cents.
The external casing and outer button wasn’t included but that’s where the creativity comes in.
That’s a nice looking switch. Something to consider for sure.
Yeah, I know about that one. I have a different idea for that kind of light, but would prefer not to use it on larger lights like the ZY-T08.
The external casing is the only thing I’m interested in. I have switches and my own design of PCBs for them, but could consider buying the actual switches if they came with nice cases. Your alu sheet looks quite nice and has given me some ideas of my own, but will keep searching a while before I go down that road. Cases like those that Old-Lumens used would be ideal.
Mike, How many do you need? Do you have scale drawings of the switch & pcb with dimensions? Do you have a physical finished size of the casing in mind? Heck... we can make the rascal! Dan.
I don’t have scale drawings and the PCB design is flexible, they cost like $1 for three so it doesn’t really matter, but the ones I have recently ordered for my ZY-T08s are 10mm, mainly because that’s the largest drill size my drill will take. I’ll drill like Old-Lumens did, leaving a shelf for the PCB to rest on, then an 8mm hole through for the wires. How deep I drill the 10mm part depends on the switch casing I find, can drill 10mm all the way through if a solution requires it.
However, I wouldn’t mind 12mm either as I have a 12mm PCB on the way for a triple XHP70 build where the host (Roche M170) already has a E-switch hole, but I got it without switch casing. If 12mm is a better size for E-switch cases I’ll just get another drill that can take 12mm drills and use that size for my ZY-T08s. I’ve posted in Old-Lumens thread asking what size drill he used for his.
How many I would need? Four is what I’d at least like to get my hands on, but could buy more as I suspect a few mining exploration friends will like the ZY-T08 once my driver and firmware is completed: Mod/Driver: ZY-T08 series conversion, MT-G2.
Anybody found cases yet? The switch solution I have used for my ZY-T08 is no good in real world conditions, mud and ice got in and froze the switch. I’d really like to get my hands on some switch cases. Any known source yet? Does anybody have some spares they want to sell?
I have a few of these, was using them to turn e-switch driver’s into Y3 drivers were they mount directly on the driver. Same switch on the Yezl with out the pins.
Thanks, but it’s not the actual switch I am looking for, it’s the casing around it. If you look at the first post it’s the five sided casing and button cover that surrounds the actual switch.
A while ago I had asked Simon if he could sell button assemblies (like S2+ tail button or side switch on F6), but he said he had no spares. Maybe J-Dub74 can convince him to sell some? S2+ button is great since it’s threaded and I guess it shouldn’t be to hard to fit it as side switch.
