I right now need one for signals in the range smaller than 1MHz, but more might be better for future use. Had a closer look at the FNIRSI-1C15, and it seems quite ok. Signal is a little flakey in the MHz-range, but the scope still gives some impressions on signals in the umpteen MHz range. Is there anything better/less expensive?
Right now just one. I’m trying to find a problem with Jetbeam drivers. Those drivers drive me nuts. Two channels would be useful. Triggering with a second signal or comparing signals would be nice, but not sure if I ever use this.
This is just a logic analyser, isn’t it? I had a clone that stopped working when they changed the driver for the USB/ser-chip.
Cheap oscilloscopes usually have a small memory depth, slow update rate and software trigger. That means they might miss trigger events for non-periodic signals and you can’t scroll much. For things like checking a PWM signal they should work, though.
Arrived yesterday. So far I only had time to measure the Aneng 8008 signal-generator, and have the Aneng measure the FNIRSI 1C15 generator. All good of course. Oh, and measured the response of one of rngwn’s LED to modulated light. Interesting new world.
Like:
Build-in battery seems to have good runtime
USB-charging
Compact set with case (zipper could be better, will probably give up the ghost after some time) including two probes, charger and USB-cable.
Price!
Dislike:
Some of the rubber keys tend to stick for a split-second in the front panel. Not nice, but no show-stopper when working with it.
There are YT-videos showing this device is good for a few MHz, and I trust them. At $60 for a complete set, I couldn’t say no and am happy with it.
It’s amazing this stuff is so cheap now. This is the advantage of the Chinese manufacturing. This would not exist with American companies. If it did, it would cost $2000.
