FW3A is almost here, which high drain battery are you feeding it?
Samsung 30Q:
VTC6 or 30Q
18650GA, but I want maximum runtime.
all the above + the LG Hg2
Samsung E35 or Q30
I created a similar thread here:
Thanks raccoon for the link.
I am leaning toward Samsung 35e. Why you went with 18650GA?
Ask 10 people, you’ll get 11 opinions…
Any mainstream high-drain cell is perfectly good, and you’d be hard-pressed to tell any Real World™ difference.
So… 30Q, HG2, VTCwhatever, get whatever’s easiest/cheapest.
I had an eBay coupon that made the 18650GA quite a bit cheaper.
Also, I think the 18650GA handles more continuous amps.
The Sanyo 18650GA slightly edges out the 35E in testing. Neither are true high drain cells though at around 10A continuous but rather mid-drain high capacity ones. I recommend the Sony 18650 VTC6 and then the 18650 30Q for up to 15A.
It’s almost here… the thread has hundreds of unread posts if I check… How close are wee
