Do NOT use spot, use multi or average. Actually, if you are on full Manual control of Aperture and Shutter, I don't think this setting is going to matter regardless, since you are not using the camera to meter the light.
I use Custom White balance set at 5400, but the Daylight setting is at 5600 and should work just as well.
"Custom" means you can create your own settings, there is a dial or something that will let you change the temperature there. Check out the owners manual...or just use the daylight setting.
Custom setting in your camere (Fujifilm FinePix S8000fd) doesn't support setting the white balance manually (by entering the Kelvin value). It requires you to use grey card (or white paper) to measure the color temperature of ambient light => not very suitable for beamshots.
=> Just use "Daylight"-setting and be happy with it.
On my Canon 30D the Custom WB setting will let you link to a previously taken shot of a sheet of white paper, as a reference for subsequent shots under the same lighting. This would again neutralize the beam tint (like Auto WB, only more accurately), which is what we want to avoid here.
On my camera, the setting that lets you manually select the color temperature is "K" (for Kelvin).
I suspect that on ILF's camera "Fine" stands for daylight, since this setting really can't be missing.
EDIT: Yep, the SUN icon! - why did they name it" Fine"?
You guys are ate up on this camera stuff. And I mean that you are educating a dumb redneck like me on all this white balance and shutter speed and focal stuff.
TK70 on turbo during the daytime at 10ft. I tried auto and it underscored it. Manual settings won't work inside which I found out already. I went to the SP2(nite mode setting) and it's better but still underscored.
WARNING: Color space tagged as sRGB, without an embedded color profile. Windows and Mac browsers and apps treat the colors randomly.
Images for the web are most widly viewable when in the sRGB color space and with an embedded color profile. See my Introduction to Digital-Image Color Spaces for more information.
EXIF — this group of metadata is encoded in 3,084 bytes (3.0k)
Camera Model Name
FinePix S8000fd
Software
Digital Camera FinePix S8000fd Ver1.01
Modify Date
2012:05:26 16:50:08 1 hour, 16 minutes, 32 seconds ago
Y Cb Cr Positioning
Centered
Copyright
Exposure Time
1/150
F Number
2.80
Exposure Program
Landscape
Exif Version
0220
Date/Time Original
Create Date
Components Configuration
Y, Cb, Cr, -
Shutter Speed Value
1/147
Aperture Value
2.80
Brightness Value
5.9
Exif Image Size
640 × 480
Make
FUJIFILM
ISO
64
Exposure Compensation
0
Max Aperture Value
2.8
Metering Mode
Multi-segment
Light Source
Unknown
Flash
Off, Did not fire
Focal Length
4.7 mm
Flashpix Version
0100
Color Space
sRGB
Sensing Method
One-chip color area
File Source
Digital Camera
Scene Type
Directly photographed
Custom Rendered
Normal
Exposure Mode
Auto
White Balance
Auto
Scene Capture Type
Night
Sharpness
Normal
Subject Distance Range
Unknown
Print Image Matching
(28 bytes binary data)
Compression
JPEG (old-style)
Focal Plane Resolution
2,801 pixels/cm
Orientation
Horizontal (normal)
Resolution
72 pixels/inch
Thumbnail Length
2,168
PrintIM
PrintIM Version
0250
Print IM 0x0002
0x00000001
Print IM 0x0101
0x00000000
JFIF
JFIF Version
1.02
Resolution
72 pixels/inch
File — basic information derived from the file.
File Type
JPEG
MIME Type
image/jpeg
Exif Byte Order
Little-endian (Intel, II)
Encoding Process
Baseline DCT, Huffman coding
Bits Per Sample
8
Color Components
3
File Size
16 kB
Image Size
640 × 480
Y Cb Cr Sub Sampling
YCbCr4:2:0 (2 2)
Composite
This block of data is computed based upon other items. Some of it may be wildly incorrect, especially if the image has been resized.
Aperture
2.80
Scale Factor To 35 mm Equivalent
15.1
Shutter Speed
1/150
Thumbnail Image
(2,168 bytes binary data)
Circle Of Confusion
0.002 mm
Field Of View
28.4 deg
Focal Length
4.7 mm (35 mm equivalent: 71.2 mm)
Hyperfocal Distance
3.98 m
Light Value
10.8
This application uses Phil Harvey's most excellent Image::ExifTool library, version 8.91. Histograms created with ImageMagick.
Jeffrey last modifed this viewer on May 7, 2012.
This thread got me screwing around with my cheap point and shoot (Fujifilm vj100) it has a semi user programable mode so I took these two pics with ISO 400 (user adjustable), 1/4 sec shutter and F3.2 (both of which I can't seem to change manually).
Here is the cheap zoomie I am to lazy to look the name up on on high,
and here is the same light, with the same settings on low,
since the setting are the same between the two, the beam shots I take are somewhat useable for comparison between pics using the same settings right?
para-frame, if you were in manual mode then you should have been able to set the shutter speed and aperture independently of each other. I'm not familiar with the Fuji cam you're using but if it does indeed have a "manual" setting then it should have not been a problem. Check with the manual: these point-and-shoots can be very confusing to operate, sometimes. I've found that a full pro-DSLR is easier to figure out and work around.
It is an automatic mode with limited adjustablity, I just checked the manual. Oh well, I can always just steal...er borrow by bros D200 or whatever it is if needed.
I agree, a good SLR (all the ones I own are film) are much easier to set exactly how you want them, no sweeping through hidden menus, everything is right there in black and white.
[/quote]
Digital cameras depreciate terribly quickly. I picked up a 20 month-old, 99% new condition Nikon D40x (full box set) for a third of the original price! . You could probably find yourself a good bargain if you looked around. Come to think of it, I haven't bought any photo stuff brand-new since 2008. (I buy my flashlights new, though)
I just tried some beamshots too.. tried, because I didnt really succeed. My camera can be adjusted between F3.3 and F6.3 and 1/320 to 1 sec. Nothing really looked like I saw it, F3.3 and 1/2 sec was close.. its a Lumix TZ20, I didnt find anything to get longer exposure.
/edit: Manual says up to 60 sec exposure is possible. Now I have to find it.. I used ISO400 btw. Any better recommendations for settings on such a limited camera?
At a aperture of f/5.6 (ISO400, WB=daylight) take a series of exposures at, say, 1/8 (sec.),1/4, 1/2, 1", 2" 4", 8". Then scroll thru the images and see which one works for you. If the images are too dark then start your exposures at 1/2 sec and do the same (work downwards). If they're too bright then start at 1/30 sec and so forth. Btw, usually focusing manually before-hand is best. In low-light conditions any cam will struggle to attain focus. A good tripod is essential. Also, at longer exposures, use the self-timer of your cam to avoid shaking the whole rig. Yes, I know it's bothersome... that's why you gotta appreciate the effort those guys put in to give us those beamshots (especially outdoors)
Oops ! Sorry I missed that part about your cam only going down to 1 sec . If the images are too dark, then up your iso to 800 or higher if possible, and use max aperture. Then start at maybe 1/15 secs. and work downwards. Unfortunately, anything over iso 400's gonna be really grainy/blotchy where compact cams are concerned. Good luck and good shooting !
