Which solder paste for LED reflow?
Kester EP256, nothing else. To me the MG Chemicals sucks.Kester EP256
The thickness of alloy is very small to have a significant effect on final heat dissipation. An more narrowed space- the p-n junction to thermal pad. You was compare the junction themperature with different alloy, with infrared thermometr?
It is significant. 50W/MK vs 86W/MK TC made huge difference in output. Haven’t tested 19W/MK vs 50W/MK but I suspect the difference would be much greater.
[Clemence]
Someone used this Good for leds?
It’s works good but not my favourite. Keep it in cool in an air tight container, gets dry fast when left open overnight. I prefer higher oily flux content. Get the syringe container for longer shelf life.
[Clemence]
I’m new with soldering paste and bought this paste from ali:
soldering paste
When heating it with hot air it doesn’t realy melt and the structure stays the same(tried temperatures from 150-450°C), also the color of the paste stays grey and I assume it should get silver when melting(like tin)?
It doesn’t get realy hard when cooled down, I can scratch it of with my fingernails
I stored it in the fridge(4°C) as soon as it arrived here, but it did 2 weeks from China till here, maybe the higher temperature within shipping time did something with the paste?
i get mine from digikey, they ship in cold container like medicine, or perishable food, if the paste requires it. i usually buy small quantity, and i do not buy a lead free, i do not believe a lead solder under the led, in a sealed light is a cause to be concerned, but it makes more reliable joints. to be honest i never even look at brand, i used several different brands i got from them, not one gave me an issue.
Reflowing really is a area in which good quality paste can save you alot of headaches. If you happen to find some cheap stuff that works good then that’s great.
In my opinion you will save time and money spending a little more and buying good paste to start with.
This is what I use and has worked super, I have had no reason to try anything else.
https://www.digikey.be/product-detail/en/chip-quik-inc/SMD291AX50T3/SMD291AX50T3-ND/5130159
Others might have more recommendations that work great too, but this one is all that I have ever needed.
Edit: Didn’t realize I had already commented in this thread, double post. :person_facepalming:
In reflowed my first led today and it stuck
Happened to have a triple mcpcb with one led that died a horrible death , so reflowed another one in its place !! With a soldering iron , heated up the sides , and under the pcb
It came off in time
Cleaned and tinned the pads and under the new led going on
Fluxed the pads popped on the new led and heated up the sides with a soldering iron
But if a get to fix but it took and works
Maybe I’ll heat the mcpcb board under when I’ve got time
But for a ghetto fix it worked
I used lead solder
How possible solder past Sn63/Pb37 melt at 148 degree?
www.aliexpress.com/item/1005001640757014.html
I don’t know. That mixture should be closer to 180*C. It’s possible they are listing it at a lower temperature in order to boost sales when it’s really going to melt at a higher temperature. If it really does melt at 148 maybe it’s because of the flux they are using? Hopefully somebody here can tell us more.
As a side note, I personally stick to name brand products from stores I trust. There are some shady products out on the market.
Edit: I just noticed that the description says it is lead-free while the picture says that it is 37% lead. So something seems pretty fishy.
Same reason why you can get a 9990lm light that runs off 3 AAA cells.
And this is the standard type,183°melt Microns: 20-38um
https://www.aliexpress.com/item/4000341198680.html?spm=a2g0s.8937460.0.0.10212e0eXDaK5v
It’s the syringe version better for long storage than jar?
Both sealed but once jar opened air will enter.
Hope there aren’t clones for this brand
https://www.aliexpress.com/item/33045181014.html?spm=a2g0o.cart.0.0.331c3c00Hcdujp&mp=1
Does anyone want some free solder paste?
Order this.
Make a video of a regulated iron set to 170 degrees, unable to melt it.
Ask for a refund.
I got some free solder this way twice while seeking a legit SnBi brand. Though TBH quality was really low, not worth the hassle in my case. In my videos I actually compared to regular Sn60Pb40 solder which melted earlier than the fake SnBi.
www.aliexpress.com/item/4001224951324.html?
Number 4 should be Sn/Bi,but who know.
I got a Mechanic SnBi solder wire that turned out to be fake.
QY-309Bi seems real.
BTW, I would NOT recommend it for LED reflow.
Thermal conductivity is worse than SnPb and I remember how Led4Power expressed concerns that low temperature joints were mechanically much weaker.
Sometimes the translation is SHOCKINGLY bad (and wrong).
I mean, this is ridiculous:
Lead-free Low Tin
and
Sn63/Pb37
