I need to use a wireless router for a bit to download gps maps for offline use (no data plan) but i can’t find the power cord for the router, it needs 5V and 2A, and i have a usb plug adapter that puts out 5V and 2A, so if i splice a usb wire which i am willing to sacrifice which wires do i use?
Also will it put out the full 2A or does it need some sort of signal from the device to do so?
You can always use one of those portable power packs…but they are limited in the output
I have an OSHPark project where a guy designed one that is capable of pushing 3.6A
Remember those el-cheapo portable power units that people were looking at (I bought 5 of em)…this is a MUCH better version of those…built in a case where you can easily remove the battery…think a strip of packaging tape or kapton wrapped around an 18650 and the body [to keep the battery from falling out]…viola…portable power unit, without the tape…it becomes a very solid TP4056 based 18650 battery charger I am thinking this is the route I am going to go from now on…no more needing to get those ones playing chinese roulette…this one is a KNOWN good setup and it won’t break the bank!
mine only charges to 4.11V and its replacement charges to 4.05V so not so grand
on the plus side it had low battery protection, at 3.58 volts it stopped running, my thing was only 25% downloaded so i’m running it straight off a 5V2A usb wall plug
