I understand that when you shine a light toward an object, that only a small portion of that light is reflected off most surfaces.
I understand that what light is reflected off those surfaces is scattered and only a portion of it bounces back to the users eyes.
I understand that only part of the light from the source makes it to the object because of inverse square.
WHAT I DO NOT UNDERSTAND is why if I am standing the receiving end, outside the range of the flashlight far far away I can still see a very bright light when I look back to ward it.
If I was on a mountain top in the desert and 20 miles away in the darkness a car was driving across the valley floor I would be able to see it perfectly. WHY?
I cant get my head around why inverse square law would not seem to apply here. At 20 miles away if I was holding a light meter I would be getting ZERO lux from those headlights.
It seems like since I was outside the range of the light none would be hitting my retinas. But that is not the experience I am having.
I think it has to do with usable light but I will let the experts answer this one. Similar explanation why you can see a star from earth but if you were standing on that star you could not see the earth.
Your eyes focus the light from the flashlight into a small point, and your eyes are dark adapted. You can easily see many individual stars if the sky if there is little ambient light (think of every star as a distant flashlight) but even all the stars combined are not enough to walk without tripping (Wikipedia lists moonless clear night sky with airglow as 0.002 lux, so the starts themselves are even fainter).
My opinion is that light always makes two trips. If it only made one, everything would be blackness.
If you shined a light on the moon, it would have to reach the moon and reflect back to you. If it only reached the moon but did not reflect back to you, you would not see the moon at all.
Nocturnal Lights Nocturnal Lights. I found this article over a year ago. I’ll have to go and read it again now, but I think this is the one that talks about surveyors using fire on hilltops at night to get compass readings.
Your eyes are much more sensitive than the light meter. They receive the same lux as the meter, but are still able to detect the light. On the other hand the same lux scattered and mostly absorbed from an object returns almost nothing to your eye. You can shine a thrower at a wall and look at the spot. Now try it the other way around (and post a photo of it on r/flashlight because it’s trending over there at the moment).
The main issue is that the reflected light also follows an inverse square law, so unless you are illuminating a mirror or retroreflective surface, the returned light is more like inverse fourth power. I first learned about this while working with a company that makes depth sounders. A basic illustration can be found here: https://www.edn.com/inverse-fourth-power/
This was a huge gimmick in an infomercial some time ago. Instead of stating throw distance, they would say “this flashlight is so powerful, it can be seen from 10 miles away.”
This woulds lead many people to believe that the light has a 10 mile throw. Meanwhile in reality that light only has a 10 foot throw.
If you exposed some film to a distant light source, it would not show a point of light like our eyes see, just an inappreciable amount of basically uniform exposure caused by the dim light. The same thing happens with a light meter when the light is too dim to pick up. This is because light travels in waves and much like waves on the ocean they seem to have no point of origin. But our eyes don’t work like a piece of film or a light meter. If you put the film in a camera, the lens focuses the parallel waves of light into a point, concentrating the dim light so it stands against a dark background in a photo. Our eyes have lenses that work much the same as a camera lens. Since the light is concentrated into a point by the lens in our eyes, we can see it at great distances (billions of light years for stars).
When we shine a flashlight on something in the distance, we see only the light reflected back to us. Not only do we have to deal with the light lost on the return trip, but the reflected light is scattered and is no longer in parallel waves and will no longer focus into a distinct point by the lenses in our eyes or in the lens of a camera.
In a dark place, you can see a light on a sub-lumen moonlight setting that is pointed at you from quite a distance. Even if the same light is used in a totally dark room the eye cannot see any light being cast of a white wall 10 feet away. Sorta the same thing at work with brighter lights and greater distances.
The illustration shows two point light sources while reflected light is none.
We discussed this already:
Edit: I made this observation when I had a flashlight mounted on binoculars. The magnified image of an illuminated object was way dimmer than when looking with the naked eye. This was counterintuitive and so I made that model.
The inverse square law applies to an omnidirectional (or at least conical, which is a fixed fraction of a sphere) light source. Perfectly collimated light, like a laser beam, doesn’t diminish at all. This principle applies to both the source and the reflector. A flashlight, unless it’s a laser, is a conical light source. The reflecting surface is typically omnidirectional (roughly hemispherical) as well. To see this, imagine shining a flashlight at a white wall, and walking around the room looking at the wall from different angles. You will be able to see the hotspot from anywhere, because the wall mainly scatters the light rather than reflecting it. This, incidentally, is why retroreflective road signs look so much brighter than everything else at night — because they are reflecting, not scattering, your headlights.
