I can find the VC2L but not the SL.
we have some stocks
Huh, Vapcell have Xtar in stock?
Is the VC2SL so bad as the VC4SL for NiMH?
In what way is it bad?
None of the category options work on your aliexpress store. I click on Li-ion chargers and it says “Sorry, no matches were found for your refined search.”
we sell some vc2l chargers.
No relevant product complaints have been received for the time being
Our retail stores are not well operated, and many products sold are not on the shelves
Can you provide a link because I cannot find the VC2SL
For NiMH it´s unusable. I managed to load some cells correct but mostly it stops loading around 50% of the capacity. No matter which load current I selected it loads only with 500mA. The Grade-function is extremly slow and also unable to charge the cells to it´s max
Maybe it works with LiIon but if the VC2SL is similar to the VC4SL it will not work with most NiMH. Even with Eneloop, the benchmark for NiMH, it have problems and stop charging mostly < 75% or <50%.
Hi there, we have the VC2SL stock in our online store xtardirect.com, you could check here:
XTAR VC2SL USB-C Li-ion/NIMH Battery Charger Power Bank
That’s uhh…not reassuring.
