Hello,
I’m new here. I want to buy a bike light. I saw many bike lights on the market from 9 dollars to hundreds dollars. But I don’t know how to choose. My requires are: long battery time, waterproof, not too hot, 100-2000 lm adjustable, solid quality, budget from 40-100 dollars
Same as with flashlights: quality, features, and what the market will bear.
Quick and cheap rec would be to get a headlamp like a Boruit RJ02. Yeah, I’ve recommended this light so many times they should pay me a commission, but it does the job nicely for <10bux.
Oh yeah… “2000lm” and “not too hot” don’t belong in the same sentence.
The last couple of years I’ve been wondering whether a dedicated bike light is still necessary. Flashlights have become so powerful yet compact, why not mount one on a bike? Then I will also at all times have a flashlight with me. You only need a clamp, that’s it.
That’s what I do. I’ve even gone so far that I’ve added a hole for a switch contact to one of my lights. The plan is to just put the light in the clamp and plug in a cable for handle bar mounted E-switch access.
Hi,
I am to suggest this light NightFighter Quantities are limited,
This brand has be re-branded as Revtronic and can be found on Amazon here, although the Amazon price is much more.
This is not too expensive and it does include a decent battery pack and charger.
The long battery life requirement will need a li-Ion battery pack of more than one cell.
A lot of lights offer generic four cell battery packs, the Achilles heal of bike lights These packs are hardly water resistant.
These battery packs are advertised are water resistant “high quality”
Most bike lights are not completely water proof, they can survive some rain but not immersion.
I prefer the self contained bicycle light, the cells are within the light
Fenix brand has some styles, The brand Ituo Light is another, but these lights get pricey.
My latest bike light is a Thrunite TN4A. Pricier then the other options above, especially when you add in a handlebar clamp and 4 eneloop batteries. Ranges from 15 to 1150 lumens. I find that the 550 lumen setting is sufficient. I really like that it runs on eneloops. Finding a clamp for your bike is hard though. The one I got does not have a strap quite long enough to go around the TN4A, but it was not hard to fix that. I like that the batteries live in the light, not in a pack you have to store somewhere else. If you want to take the light off the bike, it is very easy. A bit big, but really more compact that a light and a seperate battery pack. Waterproof to 2m I believe, I have run it in a glass of water for 30 minutes or so.
check it out!
These mounts are pretty expensive, but solid as a rock. I’ve never used them on a road bike, but on mt. bike handlebars, they’re easy to install and reliable.
i wanted flashlights to work on my bike
i tried the clamps
they are ok, i admit, and cheap
and i hate buying extra stuff
but for various reasons i decided that for me, even $25 bike lights work better than flashlights
another reason is, i like a floodier beam on my bike than any of my flashlights
actually, the li ion bike lights were my gateway drug to flashlights
i was looking for something better than $70 incandescent bike lights with nicad or nimh batteries
dim, short lived, heavy, troublesome
then the cheap bike lights came
this was maybe 8 years ago
then somehow i found out that flashlights also used single cell 18650s, they weren;t just sold in 2S2P 8.4V versions
this was after i had discovered 16340 powered LED flashlights
the 18650 was a revelation
so
my history
maybe for me, since the bike light came first, i would rather keep one
i do always ride with a flashlight in my pocket though
just in case
i think i used it one time as a bike light
What is the max and min diameter of flashlight these mounts can hold?
I’m guessing that the side with the screw goes on the handlebar and the open side is for the flashlight.
