You may get by with 6 x 1.5v D cells, because of voltage sag. I don’t know what the exact voltage sag will be, but I think with any alkalines it will be substantial. In fact, if 2 x 4.2v Li-Ion works, then surely 6 x 1.5v D cells cannot be too much.
My only issue is thinking resting and nominal voltage.
As 2 x li-ion is 8.4v resting, but only 7.4v nominal.
I haven’t put a D cell on a DMM for ages, but I think a fresh resting voltage is more like 1.65v or something. 9.9v for 6.
Think I’ll try it on 12 AA Eneloops 2P6S and see how it does for starters. I can compare amp draw and lux readings vs 2 x li-ion. Will have to wait a few weeks for the emitter though.
You just will not get the amps out of an alkaline cell to kill an MT-G2, remember you need more than 16A ! So what will it deliver? Perhaps 3 or 4 if you are lucky?
NiMh is the same story, they have very high amp capability but also a lower voltage. When fully charged, 6x1.32V=almost 8V, and even without any voltage sag you stay within 16A, more likely it will be between 4A and 6A.
I long ago had some M@g lights — 4, 5, and 6-cell — built long ago with four Luxeons, direct drive — they were ok with alkalines, but overheated fast with NiMH Ds
I got an MTG2 mounted on copper directly thanks to venturebloods heatsink sales….Mine was Direct Drive with copper to LED bonding so, maybe that helped.
Anyhow in my 6D Mag with 6 Tenergy NiMH D cells it did work great as expected.
I than added an extension and ran 7 Tenergy NiMH D cells and saw like 9A at tailcap if I recall correctly. Worked great too and the tint was pure white bliss.
