Hello all, greetings from Spain.
I am new to this forum, and I am sure many people will be able to help me with my new “weekend project”
I have been given an old Winchester large flashligh. I don’t have photos now, so I put a google image photo:
http://www.flashlightmuseum.com/Winchester-Flashlight-5-Cell-Chrome-Plated-Miners-Light-with-Push-and-Slide-Button-Switch-5D-1941
My idea is making the modification to LED or several LEDs, and using 18650 batteries, as I have plenty of them from broken HP laptop batteries.
I have a model lathe and a milling machine at home so I can make easily any ring or similar part I may need.
Has anyone attempted such modification??
I have to possible ideas:
1-buying a led lamp, the one used for simple modification of the maglites. The lamp should physically fit on the old Winchester light.
http://www.amazon.es/dp/B00A37QOI2/ref=asc_df_B00A37QOI231979810/?tag=googshopes-21&creative=24538&creativeASIN=B00A37QOI2&linkCode=df0&hvdev=c&hvnetw=g&hvqmt=
Also, I would fit inside the flashligh as many 18650 cells as I can fit, using 2 parallel system to get 7,2 volts, and 3 series, to get maybe 6000mA
2-buying a new led head, that contains 5 or 6 Cree Leds. This head is supposed to retrofit bug maglites.
http://www.dx.com/es/p/5-cree-q5-5-mode-1000-lumen-white-light-drop-in-led-module-52-7mm-42mm-8-4v-max-35244#.VsGncPnNwdU
Diameter is around 52mm, and as the winchester flashlight head diameter is about 74mm, I would make an Al ring to hold it in place. Again, I would fit as many 18650 cells as possible.
Connections would be something I will need to solve at the moment.
I was also thinking if it could be possible to fit inside the electronics of a small Li-on charger, so I dont have to remove the battery pack and charge it anyway, but these is a second idea. Maybe for safety issues, it is better to remove the battery pack and charge it out side of the flashlight
http://www.hobbysportz.com/e-sky-newest-balancer-charger-2s3s-74v-111v-lipo-balance-ek2-0851
I am interested in your experience and/or comments
Regards
Paco
