Hello, looking for Armytek Prime or Prime Pro A1 with the older FAT body. Without the taper in the middle.
Don’t care if its cool or warm, Reg or Pro. Works or not.
The cheaper the better. USA would work better also.
bump
Anyone?
I would also trade a tapered tube + some cash for your FAT tube
Can you post a pic?
Ill see if I can find on tonight.
The 1st versions had tubes that were as thick as a 18650 on the outside. Later versions they removed metal on outside to make them skinnier.
1st also had 6 sides inside bezel that look odd at close range
No Love
Thanks Kawiboy 1428 That’s the light I am looking for.
:+1: Good Hunting!
TTT
Hello.can u help me? When i using the Prime A1 with ni-mh battery it turns off automatically about 10 sec. What i do wrong? Thank you
Pro?
You possibly have it programmed for li-ion
No, is a “simple” a1. How can i reprogram then to be used with nimh? Thx
I don’t think you could reprogram the simple ones
How does it act on a alkaline
Do the same
On the Pro version from off hold button as light steps in brightness, after high it will flash 3 (?)times.
After the flashes you click once for AA.
Twice for 2 AA.
Threece for 14500.
But I don’t think you need to on the Reg model
