could be new or good condition but really just need one that works that has the xp-g2. even if it is scratched and beat up as long as the light still functions. thanks
Michael
Why not but direct from the source? Not like they are expensive to begin with
For europe shipping: 15USD+Flashlight= price premium flashlight
$25 is a decent price but i don’t have even that right now. I am looking for something under $14. that is why i said used or beat up prefered as long as it works. i need it for the head basically.
Why do you need the head? For the driver? You know there are a few 10mm BLF series drivers (and another one sided CC driver with battery contact on the bottom for twisties, the tiniest10 that uses the same CC regulator circuit my RGBW drivers use with current set table by sense resistor)
Just sayin, if you are wanting to harvest the driver for some other light/project there are cheaper, BETTER ways to get tiny drivers.
the led and driver. because the led i i ended up using elsewhere and the driver seems to not work after some basic research, checking basic connection continuity and then resoldering basic points. i am not an expert but know enough to check some basic things. anyway i need something that will work in this lights body because i already modified it. i epoxied the clip to it. and filed down the lanyard hole and epoxied an N52 neodymium magnet in that space. so there you have it. low on funds and my driver not working on a light that i made likable to me. plus the mode spacing and flat regulation i like. but i don’t know much about drivers just a little. i just started getting into this. what are these other drivers? i will see if i can find some of your posts. but if you can send me some links and descritpions then that would be helpful for some one fairly new to mods. i have had a few flashlights but never really gotten into modding them, fenix, nitecore, zebralight, crelant, sunwayman, olight etc. thanks for your response.
