Looking for an old school novatac and an RA Clicky.
Thanks in advance!
Thanks in advance!
posted a couple here:
https://www.reddit.com/r/flashlight/comments/10ql31r/comment/j7gbwex/?context=3
Thank you! How do you program these for rcr cells vs. primary cells? Did you do the mod to nichia?
yes, I did the mod
there is a bit more info and pics in this post
the process to use CR123A is described in this manual:
Read the section titled “Resetting Your Light”
there are actually 3 different types of reset… you should read all 3 descriptions to get oriented.
the battery detect for CR123 only needs to be done once, as long as you keep using CR123 it will be remembered, but if you switch to 16340, that will automatically reset the battery low voltage cutoff for 3V, which is proper for LiIon, but not good for CR123…
if you insert a CR123 after a 16340, without doing the battery detect reset for the CR123, the light will think the CR123 is battery is still a LiIon, which is supposed to be shut off at 3V. This is not what we want… when using disposable CR123…
happy to share more Novatac info any time (even if you dont buy from me…)
What are you asking for it?
$150
