WTB: UltraFire V6-T60
Anyone got any UltraFire V6-T60’s lying around. Working or non working as I only need the front glass but happy to take the whole thing off your hands.
Sorry for the interruption, but front glasses of flashlights are about the only parts of it that are available all over the world. Even if it does not fit “on first sight” it can be made fitting. I don’t know where you live, but shipping can be done in an envelope for letters, while sending lights in parcels may kripple your wallet.
Maybe you can tell us the dimensions of the glass you are looking for.
BTW: welcome to BLF :slight_smile:
Thanks very much, but I’ve realised that since that one’s been broken that I do quite like the form factor etc of it as its quite different to most of my other torches. Hence the request to see if anyone has a one lying around, that they no longer use as I’d happily look to get a couple more as there doesn’t appear to be torches with that body etc anymore.
Thanks for the suggestions on lenses though, but I thought that lenses not lenses were equal and they had an effect on the beam due to shape size coating etc. For reference, the V6-T60 appears to be circa 22mm where most of my others are 20 and don’t fit.
If nobody responds with some lights, it should be easy enough to buy a new lens to fit. Kaidomain is always a great source for the variety (or their sister store “LHT Flashlight Store” on aliexpress). If you happen to have a piece of the old glass to measure thickness, that would be helpful but the usual 1.5mm thickness suits most lights. If you drop your spare 20mm lens in there maybe you can approximate the extra width needed (or the same with a caliper on the bezel opening plus the thickness of one side). Lenses don’t have a huge affect on the beam, pound for pound, assuming you’re replacing with the same-ish thing. Flat lenses…coated or clear, either way, although sometimes one or the other can make a small but appreciated difference.
KD a/r coated lenses
This looks like the only uncoated one they have right now, probably a good candidate: 21.3 x 1.6 uncoated lens
LHT on aliexpress: https://www.aliexpress.com/store/708513
