Hi maukka, please pm me your paypal info and price… i am ready to purchase. Thanks.
I added you to the list. I’ll PM you with the details early next week when I have measured the next batch of lights.
Ok. Thanks.
So, I need some confirmation on my NW numbers. Reference numbers in yellow.
Does it make sense that the multiplier should be higher for the CW than the neutral? For some reason, I was thinking it would be the other way. Everyone says CW read higher, which makes me think I would need a lower multi for them, to bring them down.
Using a Dr Meter LX1330B in my sphere.
Getting an average of 0.1994 for the NW and 0.2081 for the CW.
The convoy light is very consistent with different battery voltages and light head temperature (back to back tests). The 348 is a bit more sensitive to the voltage and more so with the temperature (back to back tests always show lower numbers).
Do I keep digging or call it good?
Maukka, what voltage are your eneloops when you install to test? right off the charger (I get about 1.51v) or rested (I get 1.38v that way).
I also graphed (linear) the difference across color temps I have on hand. I’m hoping the linear relationship is a good way to go. Way easier with just two data points.
I test with the Eneloops right off the charger (within 20 minutes usually). I would think that the voltage drop when the light is turned on will be much larger than letting them rest for a couple of hours. That’s why I included the 60s number. The light temperature will have a bigger effect than the battery voltage, since the output drops very rapidly at the beginning but not at all after the temperature has settled even though voltage keeps dropping.
It seems your readings are very stable between different tests.
Meters react very differently to different wavelenghts as djozz’s latest lux meter test shows. For example, the noname LX-1330B reads 7.5% low on the 4500K 70 CRI Supwildfire Mitko thrower and 3% high on the 4000K 90+ CRI Sofirn SP33 compared to a good meter.
Awesome. Thank you. I’ll call these results good, based on this particular dr meter. I’ll just re-run calibration every once in a while to make sure the sphere is reading what I expect.
Nicest part is now that I have your calibrated test lights, I can grab a better meter, down the road, and recalibrate accordingly.
These test lights are really a game changer for the entire hobby. Thanks again for offering them.
The S2+ uses PWM on the low and mid modes, but the integration time in lux meters is much slower than the 4.6 kHz on the light output. Shouldn’t affect the readings at all.
Is the PWM what causes the S2+ to buzz on mid mode?
Please add to list for one set batch 4.
All shipped! :+1:
maukka,
If these are still available I would like to purchase a set. Please let me know if you are still offering these. Thank you.
Jeff
Yeah, I have a couple of sets ready to ship immediately. Will PM you.
maukka,
Thanks. I have sent money via PayPal and returned your PM with the info you requested. Thanks for letting me have a set of these.
Jeff
Hi maukka,
I would like to order one calibration set. I hope you still offering these. Please contact me. Thanks!
Kasper
Yes, one set left for now. Takes a week for me to prepare more after this. PM sent.
Hi Maukka,
I’d be keen on a kit shipped to New Zealand. Just received Texas’s PVC Lumen Tube and would like to compare readings.
Sure thing. I’m out of measured sets, but I’ll probably have some ready next weekend and will PM you then.
Awesome, thank you. No hurry
Will different 18650’s effect the calibrated reading? I’d be using the 30Q, NCR18650B or NCR18650GA. Should they read the same on Med?
There’s no difference between different batteries, since the S2+ uses current regulators at a very undemanding level.
Hi Maukka, I’m in for one set.
- Clemence
These have been shipped now.
